LCD BARgraphs
Results 1 to 40 of 233
Thread: LCD BARgraphs
    mmm, as far as i know... grandpa 16F84 have no A/D converter ... so ADCIN will never ever works with... hence why you have some strange error... i missed that forum
    Hi mister_e,
    you are right...but...
    i tryed to comment the lines :
    'DEFINE ADC_BITS 8 ' Number of bits in ADCIN result
    'ADCON1.7 = 1 ' Right Justify AD result
    and
    'adcin 2,value
    and still the same errors
    mm, i don't remind to already have this problem... token and line # mmmm
    which compiler and which version are you using?
    Yup, it's probably the version.
    In Post #110 there is an image from Marin that also has the same "Bad Token" errors.
    Attachment 1922
    The problem was PBP version 2.30 (it's just too old)
    HeHe: Beat him by a minute
    @ post 110, i think i found 1 solution... or at least some tips... configuration fuse does not seems to be the one for an 16F877 anyways, and the comment should use ; instead of '
    for this one... i don't know .. still thinking of the version !
    yeah...i guess it's the version as my version is old as well.
    thanks anyway
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
