I think I am,
trisb=1 is equal to:
trisb=%00000001
Isn't this bit 0 of port b set as input?
I think I am,
trisb=%00000001
Looks good ...
I tried THAT in MPSIM ... Works Great ...
INCLUDE "C:\PBP\MODEDEFS.BAS"
INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
LED1 VAR PORTB.2
trisa=1:trisb=1:trisc=0:trisd=0:trise=0
PORTA=0:PORTB=0:PORTC=0:PORTD=0:PORTE=0
OPTION_REG = %00100001 ; Set TMR0 Prescaler to /2, RBPU on
adcon0=%10000000 'Fosc/32, ADC ON
adcon1=%10001110 'Right Justify, RA0 Analog, rest Digital I/O
INT_Handler INT_INT, _ToggleLED1, PBP, yes
INT_ENABLE INT_INT ; enable external (INT) interrupts
pause 1
GOTO Main
'---[INT - interrupt handler]--------------------------------------------------
ToggleLED1:
high LED1: pause 100:low led1
@ INT_RETURN
I just modified OPTION_REG value cause little things seemed strange to me ...
try it ... huuu ... is processor a 16F877 ????
Yes Alain, MCU is 16F877, but this is minor.
Do you mean that with OPTION_REG=$81 does not work also at your test?
I have not the board with me at work now. I will test it late today.
I have an old 877 here...
I'll breaboard it ...
We'll see !!!
Hi, Ioannis
YOUR code has passed the Breadboard test ...
Works as expected ... ( little flash when PORTB.0 tied to ground )
Looking at the PICDEM2+ schematic some more, it seems that there might be a conflict with PORTB.0
<img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1794&stc=1&d=118289364 1>
With J6 installed (has to be for the LED on PORTB.2), the LED on PORTB.0 may not allow the voltage to rise far enough to register a HIGH level.
I joined in this quite late, but on the original bargraph code posted by Darrel (and also the interrupt code posted elsewhere) I have one thing to say....WOW Darrel. GENIUS.. BOTH of these snippets have saved me hours of work on a project I'm working on.
I needed to poll an array of front panel switches every few milliseconds AND service a bargraph update AND change the frequency of a HPWM signal all at set times, I was in the process of writing an RTOS for the PIC to allow me to use queued commands executed on a priority/time basis, then these two pieces of code went live.
OK, you killed my six months of work on the RTOS, but I'm not complaining. Everytime I see a new posting by you I just KNOW it's gonna be soething that makes my life that little bit easier.
A huge thanks and keep up the excellent work.
That's Great Sean!
Always nice to know it's not going to waste.
Hope it makes you money, or
Impresses the boss, or
Get's you an A+ on the project, or
simply presserves the hair, so it can fall out naturally later.
Best regards,
