Hi, Darrel
Could you explain those lines to me :
lines = 0x10000001 ; Define the Styles
boxed = 0x10000002
blocks = 0x10000003
(From LCD_Bar.inc ) ...
My MPLAB 7.30 seems not to understand it ( comes in red ) ... nor me !!!
Hi, Darrel
boxed = 0x10000002
blocks = 0x10000003
Hi Alain,
Those just assign some unique ID's to the words lines, boxed and blocks.
I used numbers outside the 16-bit range of PBP just to minimize confusion for myself. Then when PBP uses the number, all it sees is 1, 2 or 3.
I haven't bothered downloading the latest MPLAB so I hadn't seen any problem yet. But it should be ok to just make them 1, 2 and 3
<br>Code:ASM lines = 1 ; Define the Styles boxed = 2 blocks = 3 ENDASM
Hi Acetronics
I had the same problem, when you use the macro, be careful about the letters upper and lower case thingy, I mean Blocks and blocks are different when you use MPASM. Darrel wrote blocks in LCDbar_INC file in the difintions, so you have to use blocks, not Blocks in the macro, the same applies for lines and boxed. This worked fine for me.
For example:
In order to change to Blocks, Lines, and Boxed. Instead of block, lines, and boxed, you have to change the following in LCDBar_INC file:Code:' In LCDbar_INC file you will find the following definitions that darrel wrote: ASM lines = 0x10000001 ; Define the Styles boxed = 0x10000002 blocks = 0x10000003 ENDASM ' No need to change them nay way... In your code, you will use this macro: ; BARgraph Value, Row, Col, Width, Range, Style @ BARgraph _VOL_L, 2, 0, 20, 255, Blocks ' Doesn't work ; BARgraph Value, Row, Col, Width, Range, Style @ BARgraph _VOL_L, 2, 0, 20, 255, blocks ' Works fine
And this too:Code:ASM Lines = 0x10000001 ; Define the Styles Boxed = 0x10000002 Blocks = 0x10000003 ENDASM
After that you can use Blocks, Lines, and Boxed in your code macro.Code:if ((Style >= Lines) & (Style <= Blocks)) ; Is Style a valid constant ? MOVE?CB Style, _BAR_style else ; NO, treat it like a variable MOVE?BB Style, _BAR_style endif
Seems like a lot of work to rewrite a program to use a different Case, when you can just turn off case sensitivity for MPASM, and use any case.
For MicroCode Studio Plus:From View | Picbasic Options... | Assembler Tab and Options tabThe Microchip MPASM checkbox must be checked to see the Case option.
uncheck the "Case sensitive" Checkbox
Press OK
For other editors, or dos:Add -c to the MPASM command line.<br>
Hi darrel
I could have said that, as a matter of fact, being careful about letter cases while writing a code, prevented me of throwing that note about "uncheck the Case sensitive Checkbox", thats all darrel,
I have never used an include file other than the ones provided with PBP. I am getting an error trying to load the include file from Darrel. The only thing I can think of is that I have it in the wrong place. Can someone tell me where I have to put it?
Chris
