LCD BARgraphs
Results 1 to 40 of 233
Thread: LCD BARgraphs
    Jan 2011
    Skopje,Macedonia
    Default Re: LCD BARgraphs
    define OSC 20
    CLEAR
    INCLUDE "LCDbar_INC.bas" ' Include the BARgraph routines
    ' Define LCD connections
    DEFINE LCD_DREG PORTB ' LCD Data Port
    DEFINE LCD_DBIT 0 ' Starting Data Bit
    DEFINE LCD_RSREG PORTB ' Register Select Port
    DEFINE LCD_RSBIT 4 ' Register Select Bit
    DEFINE LCD_EREG PORTB ' Enable Port
    DEFINE LCD_EBIT 5 ' Enable Bit
    DEFINE LCD_BITS 4 ' Data Bus Size
    DEFINE LCD_LINES 2 ' Number of Lines on LCD
    DEFINE ADC_BITS 8 ' Number of bits in ADCIN result
    ADCON1.7 = 1 ' Right Justify AD result
    Value VAR WORD ' Must be a WORD even though AD is 8bit
    LCDOUT $FE, 1 ' Clear Screen
    PAUSE 200
    Loop1:
    ADCIN 0, Value
    LCDOUT $FE,2,"Value = ",DEC Value," "
    ; syntax- BARgraph Value, Row, Col, Width, Range, Style
    @ BARgraph _Value, 2, 0, 16, 255, lines
    Goto Loop1
    I use PIC16F877 @ 20MHz(I use 8 MHz,too) I delete the frist line because there is an error in compiling
    New Jersey
    Hopefully someone smarter than me can figure this out. Darrel, this program is awesome by the way!
    I'm using an OLED screen and Darrel's anypin LCD program. The OLED screen works perfectly with the data displayed but not with bargraph program. Anyhow, have a for-next loop counting to 512. It runs perfectly up until 32 or so and then displays strange stuff until it hits 99 then it's good again until about 155 then bad again until about 222 then good again until 272 then bad until about 342 then good until about 388 then bad until about 462 and then it goes to 512 and loops back around. The program looks like this:
    DEFINE OSC 48
    include "LCDBAR_INC.PBP"
    '                    OLED CHANGE
    '===============================ENABLE FOR CAR PROGRAM=========================='
    LCD_DB4    VAR PORTE.0
    LCD_DB5    VAR PORTE.1
    LCD_DB6    VAR PORTE.2
    LCD_DB7    VAR PORTA.4
    LCD_RS     VAR PORTB.6
    LCD_E      VAR PORTB.7
    LCD_Lines  CON 2 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 50 ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    INCLUDE "LCD_AnyPin.PBP" ; *** Include MUST be AFTER LCD Pin assignments ****
    '                        CONFIGS
    @ __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __CONFIG _CONFIG2L, _PWRT_OFF_2L & _BOR_OFF_2L & _BORV_3_2L & _VREGEN_ON_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32768_2H
    @ __CONFIG _CONFIG3H, _CCP2MX_ON_3H & _PBADEN_OFF_3H & _LPT1OSC_OFF_3H & _MCLRE_ON_3H
    @ __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_ON_4L & _XINST_OFF_4L
    '                 SETTINGS
               '76543210          '76543210
     TRISA   = %00100110: PORTA = %00000000
     TRISB   = %00010001: PORTB = %00010000
     TRISC   = %00000000: PORTC = %00000001
     TRISD   = %11011100: PORTD = %00000000
     TRISE   = %00010000: PORTE = %00010000
     ADCON0  = %00000001
     CMCON   = 7
     SSPSTAT = %01100100
     SSPCON1 = %00100001
     BAUDCON = %00001111
     ADCON1=15
     CCP2CON = %00011100 'changed on 11/16/12
     CCP1CON = %00011100 'changed on 11/16/12
     X  VAR WORD
    MainLoop:
    FOR X=1 TO 512
    PAUSE 100
    LCDOUT $FE,148,DEC X,"    "
    '@   BARgraph   Value, Row, Col, Width, Range, Style
                        @         BARgraph  _X,   1,   0, 20,   512,  lines
    NEXT X
    GOTO MAINLOOP
    I've tried a bunch of stuff (changing the parameters on the @ bargraph line but nothing seemed to help. This is the OLED screen I'm using:
    http://www.newhavendisplay.com/specs...420DZW-AY5.pdf
    Everytime I hear Newhaven, I cringe.
    Here's your program running on a 4550 at 48Mhz in the simulator.
    So I don't think it's a programming issue.
    It could be an R-M-W problem.
    Is the LCD connected via a ribbon cable? If so how long?
    Have you tried running the CPU at 20Mhz without the PLL?
    Or it could be just another Newhaven issue.
    Have you tried a normal LCD?
    New Jersey
    I did a lot of testing last night and it does appear to be the OLED screen that has issues. I have two OLED screens mounted on two different pieces of equipment and with the code above they do the same thing. I then put a standard LCD screen (2X16) through the same tests and it worked perfectly. I now have more questions than answers.
    Why? They work perfectly with displaying letters and numbers and the OLED screen is so much better than an LCD screen. I'm guessing you've had problems with them in the past?
    That thing is pretty cool. Where can I get it?
    After some testing, here is some information that may be useful.........or may not be. With the following line of code:
    @         BARgraph  _X,   0,   0, 20,   512,  lines
    The software will work perfectly from 0 to 33. If I use a For/Next routine for 0-33, it will run with no problems for hours on end (I know it will, trust me!) When I put 0-34, it flakes out when it gets to 34 and only 34. When it rolls back around, the same thing happens. 0-33 works good and then 34 won't, up until 98 or so. I don't get that.
    By changing to the following code:
    @         BARgraph  _X,   0,   1, 20,   512,  lines
    Now 0-110 works perfectly. The only thing I did was move the column from 0 to 1! Riddle me that one!
    Also, if I just change to this code
    @ BARgraph _X, 0, 1, 20, 10000, lines
    Now it will count much higher without a problem.
    Wow, is that thing slowwwwwwww. 600uS. for just about any of the control instructions? I really think you need to check your command and data delay settings. If I was using it I would also operate it in 8 bit mode. Twice as fast..... I also suggest reading the busy flag because if you are not then you are probably sending it instructions while it is executing the last instruction.
    EN82fn
    New Jersey
    If the command and data delay settings are wrong or the device is too slow, why does it work perfectly with displaying letters and numbers? In addition, I could put a for/next loop from 0 to 33 and the bargraph routine runs perfectly hours on end. More testing reveals this:
    Range.... Number where the bargraph is not displayed correctly
    64 .... 4
    128 .... 8
    256 .... 16
    512 .... 34
    1024 .... 66
    2048 .... 132
    This means something, just not sure what. The one common thing I can see is that when one box (three vertical "l"'s) fills up, the next time the bargraph routine attempts to write to the next box, it will fail. If I adjust the column from 0 to 1, it will now allow me to successfully write four boxes instead of one.
    Maybe that is all it is good for?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
