LCD BARgraphs - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 121 to 160 of 233
Thread: LCD BARgraphs
  1. #121
    Hi mister_e,
    you are right...but...
    i tryed to comment the lines :
    'DEFINE ADC_BITS 8 ' Number of bits in ADCIN result
    'ADCON1.7 = 1 ' Right Justify AD result
    and
    'adcin 2,value
    and still the same errors
  2. #122
    mm, i don't remind to already have this problem... token and line # mmmm
    which compiler and which version are you using?
  3. #123
    Yup, it's probably the version.
    In Post #110 there is an image from Marin that also has the same "Bad Token" errors.
    Attachment 1922
    The problem was PBP version 2.30 (it's just too old)
    HeHe: Beat him by a minute
    @ post 110, i think i found 1 solution... or at least some tips... configuration fuse does not seems to be the one for an 16F877 anyways, and the comment should use ; instead of '
    for this one... i don't know .. still thinking of the version !
  5. #125
    yeah...i guess it's the version as my version is old as well.
    thanks anyway
  6. #126
    Default Bar Graph
    This is my version of the bar graph.
    '*  Name    : Bargraph.BAS                                      *
    '*  Author  : Chris Bezuidenhout                                *
    '*  Notice  : Copyright (c) 2005 Micro Developments             *
    '*  Date    : 2005/07/19                                        *
    '*  URL     : http://www.patenttrade.net                        *
    '*  E-mail  : [email protected]                             *
    '*  Mobile  : +27-72-795-0107                                   *
    '*  Notes   : This is a bargraph demo for a 2X20 LCD Display    *
    '*          : it is free to use and distribute by any one       *
    '*          : as long as this Copyright note is not altered or  *
    '*          : removed, can be used as an analog meter.          *
    '*  Device  : PIC16F877 can be altered to work on other devices *
    	INCLUDE "Modedefs.Bas"
    DEFINE 	OSC 4		' Set Xtal Frequency
    DEFINE LCD_DREG PORTA     ' Set LCD Data port
    DEFINE LCD_DBIT 0         ' Set starting Data BIT (0 OR 4) IF 4-BIT bus
    DEFINE LCD_RSREG PORTA    ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4        ' Set LCD Register Select BIT
    DEFINE LCD_EREG PORTE     ' Set LCD Enable port, for other devices, use PORT A or B
    DEFINE LCD_EBIT 0         ' Set LCD Enable BIT
    DEFINE LCD_BITS 4         ' Set LCD bus side (4 OR 8 bits)
    DEFINE LCD_LINES 2        ' Set number of lines ON LCD
    ' md Declare the Variables md
    	counter		VAR		BYTE
    	Text		VAR		BYTE[20]
    	X			VAR		BYTE
    	Y			VAR		BYTE
    PAUSE 500
    '*********Modefy first 5 characters in LCD character generator to display bargraph**********
    		LCDOut $fe,%1000000           'SET CG RAM ADD.
    		FOR X =1 TO 8
    		LCDOUT %10000
    		next x
    		FOR X=1 TO 8
    		LCDOUT %11000
    		NEXT X
    		FOR X=1 TO 8
    		LCDOUT %11100
    		NEXT X
    		FOR X=1 TO 8
    		LCDOUT %11110
    		NEXT X
    		FOR X=1 TO 8
    		LCDOUT %11111
    		NEXT X
    		LCDOut $fe,%10000000             'SET DD RAM ADD.
    '		FOR X = 0 TO 255
    '		LCDOUT $FE,1,#X,X
    '		PAUSE 100
    '		NEXT X
    LOOP1:		LCDOUT $FE,1,"This is a test"
    		LCDOUT $FE,$C0          'clear second line and display bar graph
    		LCDOUT 0                'print first character
    		for X= 0 TO 19	        'change 19 to 15 for 16 character display
    		PAUSE 100
    		LCDOUT $FE,$10,1        'move curser back and overprint previous character
    		PAUSE 100
    		LCDOUT $FE,$10,2        'move curser back and overprint previous character
    		PAUSE 100
    		LCDOUT $FE,$10,3        'move curser back and overprint previous character
    		PAUSE 100
    		LCDOUT $FE,$10,4        'move curser back and overprint previous character
    		PAUSE 100
    		LCDOUT $FE,$14          'print next character
    		LCDOUT $FE,0
    		NEXT X
     		GOTO LOOP1
    You can't teach an old dog new tricks, but I'm always willing to try.
  7. #127
    Chris,
    The Note says "can be used as an analog meter".
    How would you do that?
    Sep 2007
    USA, CA
    It's a slight variation of Les Johnson's bargraph routine, which is in his PBP book. You load the "graphics" of the bar graph into lcd memory, then print solid bars (or blocks) until the final one which is printed as the mod of 3. The above bar graphs use a resolution of five, which has the disadvantage of a space between each five. Les' uses three, because it makes the space between the characters an unnoticed and integral part of the graph. If you don't have Les' book, then look for one of the Proton samples, because they ship with it.
  9. #129
    Default Analog meter
    Chris,
    You have to use a chip with AD channels like the 16F818/819 then say for 1 volt you send your 5th character and for 1.4 volt you will send the 5th and the second character for 2.2 volt you will send the 5th character twice and then your first character so your 5th character is your integer and the first four is your decimals after the point, it give you a .2 resolution .2, .4, .6, .8
  10. #130
    Default Sprites
    You can even draw little 5X7 sprites, like a walking man or any 5X7 picture. I have a small basic compiler with some handy tools, where you can create the picture and get the data for your picture. there is also a seven segment tool, it is free to download from my site, but you can only use the compiler with the programmer from Mikro Elektronika, but the tools is handy. look in the right border for free downloads it is the first item
  11. #131
    Jan 2007
    Houston, TX
    Wink Nice Work
    DT,
    Really nice work! I will be using this on several of my A2D projects!!
    Padawan-78
  12. #132
    Smile Thanks Tyson!
    Hope they work out for you.
    You might also want to check out this one ...
    Bargraph query thread
    http://www.pbpgroup.com/modules/newb..._id=37&forum=2
    Mar 2008
    Hello !
    First of all , thanks for the LCD codes.
    I applied the code below , it works fine ; but at the first row ; " Value= XXX " always flickering ; like something is writing over the " Value = XXXX " and it's always flickering.
    What is the problem ?
    @ DEVICE pic16F877
    @ DEVICE pic16F877, WDT_on
    @ DEVICE pic16F877, PWRT_ON
    @ DEVICE pic16F877, PROTECT_OFF
    @ DEVICE pic16F877, HS_OSC
    TRISA=%00000001
    TRISB=0
    TRISE=0
    INCLUDE "LCDbar_INC.bas"
    ham var word
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 1
    DEFINE LCD_EBIT 0
    DEFINE LCD_RWREG PORTE
    DEFINE LCD_RWBIT 2
    DEFINE LCD_BITS 8
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1000
    DEFINE LCD_DATAUS 225
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2
    DEFINE ADC_SAMPLEUS 100
    ADCON1=%10001110
    LOW PORTE.2
    LCDOUT $FE,1
    PAUSE 200
    Loop1:
        ADCIN  0, ham
        ham=1023-ham
        LCDOUT $FE,2,"Value = ",DEC ham,"   "
        ; syntax- BARgraph   Value, Row, Col, Width, Range, Style
        @         BARgraph  _ham,   2,   0,    16,   1023,  lines
        PAUSE 50
    Goto Loop1
    Quote Originally Posted by karamastik View Post
    Loop1:
        ADCIN  0, ham
        ham=1023-ham
        PAUSE 50
    Goto Loop1
    That's because something is always overwriting Value = XXXX. VALUE = XXXX is always overwriting VALUE = XXXX.
    Try ONLY overwriting just the value not the whole string.
  15. #135
    Pause 50 is a bit low, try to increase it a little bit more.
  16. #136
    karamastik,
    LCD_COMMANDUS 1000 seems a little low.
    On most displays, the Home command ($FE,2) takes 1.6ms or 1600us.
    Try increasing it to 2000, some displays need even more than that.
    LCD_DATAUS 225 is pretty High. Should be around 50.
    If this one is too high, it won't cause a problem. It'll just slow things down unnecessarily.
    Mar 2008
    Can I pick someone's brain please?
    I'm at the moment trying to make an auto switchover gadget to change from running on Diesel to Veg Oil once certain temperatures have been reached, and to try and work this out I'm using the easypic5 development board.
    So far: I have a 16f877A programmed so it will switch certain outputs when certain inputs go high all and well
    It even displays what it's doing on the LCD display
    What I'd like to incorporate if its possible is this? or a variation of it the Bargraph but use it as a fuel level sensor, i.e. changing position depending on the level of the fuel in the tank (variable resistor)
    Does anyone know any code that will do that or give me a starting place to play with?
    I know I've got 2 A/D converter inputs on the developement board I can play with that have a 10K pot connected and are configured so I can change the input on either of the RA0, RA1, RA2, RA3, RA4, or RA5 pins and measure the voltage on them ( unfortunatly I'm only just learning about Pic's at the moment and know nothing about A/D and how to use it, I am learning by trying and experimenting But I am a quick learner), so IF anyone has any code they could share with me to show me how to get started with this I'd be grateful Thanks
  18. #138
    well, once you have the lcd working.. it's just a matter to have few IF-THEN conditions with your ADC value and few HIGH/LOW lines, and you should be in business... maybe i've misundertood something?
  19. #139
    I like this one. http://www.rentron.com/PICX2.htm
    It is a little more complicated than ADCIN, but it is still the method I use.
    Follow the code with the data sheet and it should become clear how the ADC works. Complete control.
  20. #140
    Mar 2008
    Your forgetting im a Pseudo Blonde
    I've no idea how to start off with ADC values or how to use them (at the moment) I've found the easiest way to learn something is by following examples that show you how to get started and then playing from there thats how I got the LCD working in the first place, and then the bargraph, then inputs and outputs... learning.. slowly!
  21. #141
    No i didn't forget
    let's see first example in this thread
    ; Initialize your hardware and LCD first.
    INCLUDE "LCDbar_INC.bas"        ' Include the BARgraph routines
    Value  VAR  WORD                ' Must be a WORD even though AD is 8bit
    LCDOUT $FE, 1  ' Clear Screen
    Loop1:
        ADCIN  0, Value
        LCDOUT $FE,2,"Value = ",DEC Value,"   "
        @         BARgraph  _Value,   2,   0,    16,   255,  lines
    GOTO Loop1
    You just need to monitor Value variable with some IF-THEN statements after ADCIN line
    IF Value>200 then
            LCDOUT $FE,2,"VALUE>200       "
  22. #142
    Mar 2008
    I think I'm starting to get parts of it I'll try tomorrow properly when my head isn't so tired
    however i do have one question, how do you tell the pic what port the input is on?
    ie if the pot was connected to portA.0 how would you tell the pic to measure and display the value of that port?
    Hope I've said that clearly enough, sometimes I'm better about thinking about things than trying to explain what I mean
  23. #143
    ADCIN 0, Value
    check the datasheet, PORTA.0 is AN0
  24. #144
    Apr 2008
    Default really appreciate the writter
    I will use it to cell voltage indicator project
  25. #145
    Default AD routine
    Quote Originally Posted by karenhornby View Post
    Here is my code for monitoring the sensors in a car. Note: this method is more accurate than ADCIN
    '*  Name    : CarMonitor.PBP                                     *
    '*  Notice  : Copyright (c) 2007 Micro Developments             *
    '*  Date    : 2007/10/23                                        *
    '*  Version : 1.1.1                                             *
    '*  URL      :http://www.patenttrade.net                             *
           OSCCON = %01100000                  'set the intrc osc change bit 4 to logic  1 for 8 MHz
           OSCTUNE = %000000
    DEFINE 	OSC		4     ' Set IRC Frequency
    DEFINE ADC_BITS 10       ' Set number of bits in result
    DEFINE ADC_CLOCK 1    ' Set clock source (rc = 3)
    IgnIn    var     word
    Altin    var     word
    Oilin    var     word
    TempIn   var     word
    ResIn    var     word               'Reserve input
    IgnOut   var     portb.0
    AltOut   var     portb.1
    OilOut   var     portb.2
    TempOut  var     portb.3
    Buzzer   var     portb.4
    ComO     var     portb.5
    SigOut   var     portb.6
    sp2      var     portb.7
    Spin1    var     porta.6
    Spin2    var     porta.7
    X        var     byte
    Y        var     byte
    TRISA = %11111111          'Porta 0-4 all analog 5 input only pull high
    TRISB = %00000000
    ADCON0 = %11000001
    Pause 2000 ' Wait .5 second
    ADCON1 = %10000010 ' Set PORTA analog and RIGHT justify result
    OPTION_REG = $7f        ' Enable PORTB pullups
    portb = 0
    low Buzzer
           gosub CIgn
           gosub CAlt
           gosub COil
           gosub CTemp
           gosub Send
    Ignition:
           if ignin = 0 then
           high Ignout
           gosub Send
           if ignin > 300 then
           low ignout
           goto Alternator
    '       if ignin > 0 and ignin < 300 then
           for y = 1 to 3
           gosub CIgn
           gosub Send
           if ignin > 300 then  Alternator
           for x = 1 to 2
           high Ignout
           high buzzer
           pause 200
           low buzzer
           pause 200
           next x
           next y
    '       endif
    Alternator:
               if ignin = 0 then goto main
           low ignout
           if Altin > 1020 then
           high altout  '?????????Kalibreer
           for y = 1 to 3
           gosub CAlt
           gosub Send
           if altin < 1020 then Oil
           for x = 1 to 4
           high buzzer
           pause 200
           low buzzer
           pause 200
           next x
           next y
    Oil:
           low altout
           if Oilin > 10 then    'This variable have to be calibrated to sensor unit
           high Oilout           'for a plain on/of it must be set to 0, the pot at minimum
           for y = 1 to 3        'if there is some contact resistance it can be calibrated acordingly
           gosub COil            'For a analog (resistive) sensor it have to be calibrated to
           gosub Send            'the sensor
           if oilin < 10 then Temperature    'So is this one
           for x = 1 to 6
           high buzzer
           pause 200
           low buzzer
           pause 200
           next x
           next y
    Temperature:
           low Oilout
           if tempin < 85 then
           high tempout
           for y = 1 to 3
           gosub CTemp
           gosub Send
           if tempin > 85 then main
           for x = 1 to 8
           high buzzer
           pause 200
           low buzzer
           pause 200
           next x
           next y
           low tempout
    CIgn:
           ADCON0 = %11000101             'start ADC  A0
           gosub notdone
           IgnIn.highbyte = ADRESH
           IgnIn.Lowbyte = ADRESL
           write 0,ignin.highbyte
           write 1,ignin.lowbyte
    CAlt:
           ADCON0 = %11001101             'start ADC A1
           gosub notdone
           altin.highbyte = ADRESH
           altin.Lowbyte = ADRESL
           write 2,Altin.highbyte
           write 3,Altin.lowbyte
    COil:
           ADCON0 = %11010101             'start ADC A2
           gosub notdone
           oilin.highbyte = ADRESH
           oilin.Lowbyte = ADRESL
           write 4,oilin.highbyte
           write 5,oilin.lowbyte
    CTemp:
           ADCON0 = %11011101             'start ADC A3
           gosub notdone
           TempIn.highbyte = ADRESH
           TempIn.Lowbyte = ADRESL
           write 6,tempin.highbyte
           write 7,tempin.lowbyte
    CRes:
           ADCON0 = %11100101             'start ADC A4
           gosub notdone
           resin.highbyte = ADRESH
           resin.Lowbyte = ADRESL
    Send:
           serout SigOut, N2400,["A",IgnIn.highbyte,IgnIn.lowbyte,altin.highbyte,altin.lowbyte,Oilin.highbyte,Oilin.lowbyte,Tempin.highbyte,Tempin.lowbyte,resin.highbyte,resin.lowbyte]
    notdone: Pause 5
           If ADCON0.2 = 1 Then notdone' Wait for low on bit-2 of ADCON0, conversion finished
  26. #146
    Jul 2008
    TURKIYE-KONYA
    Default Pbpl Bargraph
    hi darrel...
    i m using pbp 2.50b compiler and using pbpl.
    how can i use your include file with pbpl?
  27. #147
    Default Pbpl
    For each DIV32, change it to a normal divide ...
    Was: Limit1 = DIV32 10
    &nbsp; To:&nbsp; Limit1 = Limit1 / 10
    or you can combine them with the previous statements
    Limit1 = (BAR_range * 3) / 10
    for all the occurances.
    And change the WORD vars to LONG.
    Default LCD bargraph
    hi friends
    I am a new member I can little speak english maybe my errors I am sorry
    My problem is LCD bargraph How I can on pictures project. on pictures LCD 2x16 char , LCD has 32 bars per char has two bars project has two buttons minus and plus I need this projects pic basic code Can you help me. Already tahnks
  29. #149
    Jul 2008
    TURKIYE-KONYA
    Default lcdbargraph PBPL
    I TRIED YOUR INCLUDE FILE FOR PBPL AND MADE WHAT U SAID.
    IT'S WORKING GOOD THANKS.
    '*   Creates a variable sized BAR-graph anywhere on the screen  *
    '*  Name    : LCDbar_INC.bas                                    *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2005                                *
    '*  Date    : 9/8/2005                                          *
    '*  Notes   : Maximum Range is 32768                            *
    '*          : Range must always be a Constant                   *
    '*          : Value must always be a WORD variable              *
                                                   ;                        default
    BAR_width   VAR  BYTE : BAR_width = 16         ; Width of the BARgraph      16
    BAR_range   VAR  LONG : BAR_range = 100        ; Range of Values (0-100)   100   ;;;;;;;;;;;
    BAR_row     VAR  BYTE : BAR_row = 1            ; Row location (1-4)          1
    BAR_col     VAR  BYTE : BAR_col = 0            ; Column location (0-15)      0
    BAR_value   VAR  LONG : BAR_value = 0          ; Current BAR value           0   ;;;;;;;;;;;
    BAR_style   VAR  BYTE : BAR_style = 1          ; 1=lines, 2=boxed, 3=blocks  1
    ; --- Temporary vars ----
    BARtemp     VAR  LONG   ;;;;;;;;
    Remainder   VAR  LONG   ;;;;;;;;
    BARloop     VAR  BYTE
    LastCharset VAR  BYTE : LastCharset = 0
    Limit1      VAR  LONG   ;;;;;;;;
    GOTO overBAR                                   ; Skip over Subroutines
    ThreeBARS CON 0                                ; Identify the Custom Characters
    TwoBARS   CON 1
    OneBAR    CON 2
    lines  = 0x10000001                            ; Define the Styles
    boxed  = 0x10000002
    blocks = 0x10000003
    ; --- lines Style custom chars ----
    CharsetLines:
        LCDOut $FE,$40,REP $15\8                  ; Custom char 0 - 3 lines  |||
        LCDOut $FE,$48,REP $14\8                  ; Custom char 1 - 2 lines  ||
        LCDOut $FE,$50,REP $10\8                  ; Custom char 2 - 1 line   |
    ; --- boxed Style custom chars ----
    CharsetBoxed:
        LCDOut $FE,$40,$1F,REP $15\6,$1F          ; III
        LCDOut $FE,$48,$1C,REP $14\6,$1C          ; II
        LCDOut $FE,$50,REP $10\8                  ; I
    ; --- blocks Style custom chars ----
    CharsetBlocks:
        LCDOut $FE,$40,REP $1F\8
        LCDOut $FE,$48,REP $1C\8
    ; ----- Show the BAR graph -----------------------------------------------------
    ShowBAR:
        IF BAR_width = 0 then BARdone
        if LastCharset <> BAR_style then          ; If the Style has changed ?
            LastCharset = BAR_style
            SELECT CASE BAR_style                 ; Load the new custom chars
                CASE 1 : GOSUB CharsetLines
                CASE 2 : GOSUB CharsetBoxed
                CASE 3 : GOSUB CharsetBlocks
            END SELECT
    @ ifdef LCD4X20
        LOOKUP BAR_row,[$80,$80,$C0,$94,$D4],BARtemp
    @ else
        LOOKUP BAR_row,[$80,$80,$C0,$90,$D0],BARtemp
    @ endif
        LCDOUT $FE, BARtemp + BAR_col             ; Move cursor to start of the BAR
    ;;;;;;;;BARtemp = BAR_value * BAR_width           ; calc the char position
    ;;;;;;;;BARtemp = DIV32 BAR_range
        BARtemp = (BAR_value * BAR_width)/BAR_range    ; CHANGED
        Remainder = R2
        For BARloop = 0 to BAR_width -1
            SELECT CASE BARtemp
                CASE IS > BARloop
                    LCDOUT ThreeBARS              ; send 3 bars    |||
                CASE IS < BARloop
                    LCDOUT " "                    ; clear to end of BARwidth
                CASE IS = BARloop
    ;;;;Limit1 = BAR_range * 6
    ;;;;Limit1 = DIV32 10
                    Limit1 = (BAR_range * 6)/10   ; CHANGED
    		if Remainder >= Limit1 then
                        LCDOUT TwoBARS            ; send 2 bars    ||
    ;;;;Limit1 = BAR_range * 3
    		Limit1 = (BAR_range * 3)/10   ; CHANGED
                        if Remainder >= Limit1 then    ; 30%
                            LCDOUT OneBAR         ; send 1 bar     |
                            LCDOUT " "            ; no bars
            END SELECT
        NEXT BARloop
    BARdone:
    ; --- The main macro for creating BARgraphs ------------------------------------
    BARgraph  macro  Value, Row, Col, Width, Range, Style
        MOVE?CW    Range, _BAR_range              ; Range MUST be a constant
        MOVE?WW    Value, _BAR_value              ; Value MUST be a WORD variable
        if (Row < 5)                              ; Row is a constant
            MOVE?CB    Row,   _BAR_row
        else                                      ; Row is a variable
            MOVE?BB    Row,   _BAR_row
        if (Col < 16)                             ; Is Col a constant ?
            MOVE?CB    Col,   _BAR_col
        else                                      ; NO, it's a variable
            MOVE?BB    Col,   _BAR_col
        if (Width <= 40)
            MOVE?CB    Width, _BAR_width
            MOVE?BB    Width, _BAR_width
        if ((Style >= lines) & (Style <= blocks)) ; Is Style a valid constant ?
            MOVE?CB    Style, _BAR_style
        else                                      ; NO, treat it like a variable
            MOVE?BB    Style, _BAR_style
        L?CALL   _ShowBAR
    overBAR:
    but there is a problem ; when i want to use different bar type on lcd for different rows bar types are mixing.
    example:
    row1 blocks
    row2 lines
    row3 boxed
    row4 blocks
    when use it like this all rows are one type bar.
  30. #150
    Great! Glad you got it working, and thanks for the updated code.
    There's only 1 area for custom characters in the LCD.
    So you can only have one Style at a time. Sorry.
    Default Bargraph
    Quote Originally Posted by mehmetOzdemir View Post
                                                   ;                        default
    BARloop     VAR  BYTE
    TwoBARS   CON 1
    OneBAR    CON 2
    boxed  = 0x10000002
    blocks = 0x10000003
    CharsetLines:
    CharsetBoxed:
    CharsetBlocks:
    ShowBAR:
            END SELECT
    @ ifdef LCD4X20
    @ else
    @ endif
        Remainder = R2
            SELECT CASE BARtemp
                CASE IS > BARloop
                CASE IS < BARloop
                CASE IS = BARloop
            END SELECT
        NEXT BARloop
    BARdone:
        if (Width <= 40)
        L?CALL   _ShowBAR
    overBAR:
    example:
    row1 blocks
    row2 lines
    row3 boxed
    row4 blocks
    turkish mean
    özdemir dostum bu program nasıl çalışıyor uygulama şemasını ekleye bilirmisin banada resimdeki 2 butonlu bargraph uygulaması lazım yukarıda resimleri ekledim bu programı 2 butonlu şekilde düzenleyebilirmiyiz. şimdiden teşekkürler bide ingilizce yazmaya çalışım ayıp olmasın
    english mean ,maybe my errors, Im sorry
    özdemir my friend,how is run this program can you attach application circuit I need on picture bargraph application with two buttons How I can make this project can you helpme already thanks
  32. #152
    Sep 2008
    Stockholm
    Great stuff
    Worked on the first try in my latest program, which I didn't really expected
    I started to write something own, until I remembered that I had a vague memory of seeing something like this on the forum, and here it was, ready to be used
    Would be really nice to have a logarithmic scale too, I didn't really understood everything people wrote about logarithmic, did anyone come up with a quick software-only solution ?
  33. #153
    In software you need a lot of maths. So better use a hardware solution. Faster and wide dynamics (up to 64db).
    Sep 2008
    Stockholm
    But how do I do that ? a logarithmic filter ?
  35. #155
    If you mean in hardware, please look at previous post:
    http://www.picbasic.co.uk/forum/show...1&postcount=66
    The chips include a logarithmic amplifier. So you take the output of this amplifier and feed it in the analog converter of the PIC. At the input you feed the analog signal either directly or through an active rectifier.
    Loveland CO USA
    Several times in this thread people have mentioned log amplifiers for audio signals.
    See thatcorp.com THAT2252
    http://thatcorp.com/datashts/2252data.pdf
    The output is +0.3 to –0.3 volts over a 100db range. A simple op-amp will amplify the 0.6 volt signal and add an offset to get 0 to 5 volts.
  37. #157
    Nice chip, but I believe the other three (3089, 3189 and NE604) are more convienient since they work with single supply and are much wider in freq. range.
    ciberman37's Avatar
    ciberman37 Guest
    Default error in LCDbar.inc.bas
    The compiler signalise error in line 29, no is alabel?
  39. #159
    Line 29 is GOTO overBAR, and overBAR: is the last line in the include file.
    Check the end of the file and make sure overBAR is there. If not, you may have received a partial download. Try downloading it again.
    Sep 2008
    Stockholm
    What kind of licence did u put on your code Darrel ?
    I currently making a little project for a contest in a swedish electronics forum, and I really would like to use a LCD bargraph, and the rules states that I only can use includes that are "GPL or more free.", can I use this, or do I have to write something much more ugly myself ?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
