LCD BARgraphs - Page 6
Page 6 of 6 FirstFirst ... 23456
Results 201 to 233 of 233
Thread: LCD BARgraphs
  1. #201
    Default Re: LCD BARgraphs
    Chris, Just use the busy bit to confirm the display is ready for the next command.... As I said in the my first return post, the commands are processed by the display far too slowly and I see no delays in your code after any of the cursor control commands and you are probably running it in 4 bit mode as opposed to 8 bit mode which now allows for even more data to be lost. looking at the timing constraints in the data sheet, I'm supprised the thing is working at all. The processor onboard the display is probably doing far more work than your code is. If you are commited to using this type of display with it's down falls because it looks good then you MUST you it as it was intended to be used it you expect it to relay the information correctly. No more to say...
    EN82fn
  2. #202
    New Jersey
    Default Success!
    looking at the timing constraints in the data sheet, I'm supprised the thing is working at all. ....If you are commited to using this type of display with it's down falls because it looks good then you MUST you it as it was intended to be used it you expect it to relay the information correctly. No more to say...
    Anyhow, for anyone who is using a Newhaven OLED display and wants to use Darrel's bargraph routine, you only have to modify a few things, which only takes about 30 seconds to do so. Here is what you need to do:
    Make this portion of the code:
        LCDOut $FE,$40,REP $15\8                  ; Custom char 0 - 3 lines  |||
        LCDOut $FE,$48,REP $14\8                  ; Custom char 1 - 2 lines  ||
        LCDOut $FE,$50,REP $10\8                  ; Custom char 2 - 1 line   |
    To make it look like this:
        LCDOut $FE,$48,REP $15\8                  ; Custom char 0 - 3 lines  |||
        LCDOut $FE,$50,REP $14\8                  ; Custom char 1 - 2 lines  ||
        LCDOut $FE,$58,REP $10\8                  ; Custom char 2 - 1 line   |
    You have change the numbers in the other two character sets if you use blocks and boxes.
    You also have to modify this code:
    ThreeBARS CON 0                                ; Identify the Custom Characters
    TwoBARS   CON 1
    OneBAR    CON 2
    To this:
    ThreeBARS CON 1                                ; Identify the Custom Characters
    TwoBARS   CON 2
    OneBAR    CON 3
    By modifying the lines of code above, the bargraph will display correctly on your OLED screen. I tested the bargraph a few different ways and it worked 100% of the time. I hope this is able to help someone.
  3. #203
    May 2006
    Del Rio, TX, USA
    Exclamation Re: Success!
    THE CHANGES IN THE ABOVE POST ARE INCOMPLETE!!!
    If you make those modifications, you need to change all of the custom character declarations. Otherwise, the other styles will not work properly. Here are the other modifications (shown with the first set for context):
    ; --- lines Style custom chars ----
    CharsetLines:
    ; --- boxed Style custom chars ----
    CharsetBoxed:
        LCDOut $FE,$48,$1F,REP $15\6,$1F          ; III
        LCDOut $FE,$50,$1C,REP $14\6,$1C          ; II
        LCDOut $FE,$58,REP $10\8                  ; I
    ; --- blocks Style custom chars ----
    CharsetBlocks:
        LCDOut $FE,$48,REP $1F\8
        LCDOut $FE,$50,REP $1C\8
    Default Re: Success!
    So, what you're saying is that if you use Custom Character 0 on those displays, everything goes crazy?
    Displaying the wrong characters on the wrong lines.
    And by just not using Cust. Char 0, everythings AOK?
    On both of your dispays?
    That's a new one ... but it sounds typical for Newhaven.
    New Jersey
    Quote Originally Posted by SteveB View Post
    No kidding. Did you read my post?
    Yup. I tried this on both displays with different programs. Whenever a 0 is used, the display gets all wacky. It will not only display the characters on the wrong line, the entire OLED displays wacky stuff. (I took two crappy cell phone pics of the differences). You also have to change the LCDOUT commands too. If you don't, it will still work but the box won't be filled out completely.
    I tested it a bunch of different ways and I couldn't make it fail. Perhaps I didn't test every single mode but what I did test (what I normally use) worked perfectly!Name:  IMAG0306.jpg
Size:  47.4 KBName:  IMAG0307.jpg
  6. #206
    May 2006
    Del Rio, TX, USA
    Darrel, I hope you don't mind.
    Here is a modified version of Darrel's code that accommodates the flaw in the Newhaven Display Firmware preventing use of CGRAM location 0. (Changes I made are highlighted in blue)
    '*   Creates a variable sized BAR-graph anywhere on the screen  *
    '*  Name    : LCDbar_INC_MOD1.bas                               *
    '*  Original:                                                   *
    '*  Author  : Darrel Taylor                                     *
    '*  Notice  : Copyright (c) 2005                                *
    '*  Date    : 9/8/2005                                          *
    '*  Notes   : Maximum Range is 32768                            *
    '*          : Range must always be a Constant                   *
    '*          : Value must always be a WORD variable              *
    '* Modified : By SteveB on 11/23/2012                           *
    '*          : The original include has been modified to         *
    '*          : accomodate a flaw in Newhaven OLEDs firmware.     *
    '*          : By using the define below, it will adjust the     *
    '*          : custom CGRAM character locations used to 1-3      *
    '*          : (vs. 0-2).                                        *
    '*          : If using a flawed Newhaven Display add the        *
    '*          : following define BEFORE the INCLUDE statement:    *
    '*          : DEFINE NEWHAVEN_DISPLAY 1                         *
    BAR_width   VAR  BYTE : BAR_width = 16         ; Width of the BARgraph      16
    BAR_range   VAR  WORD : BAR_range = 100        ; Range of Values (0-100)   100
    BAR_row     VAR  BYTE : BAR_row = 1            ; Row location (1-4)          1
    BAR_col     VAR  BYTE : BAR_col = 0            ; Column location (0-15)      0
    BAR_value   VAR  WORD : BAR_value = 0          ; Current BAR value           0
    BAR_style   VAR  BYTE : BAR_style = 1          ; 1=lines, 2=boxed, 3=blocks  1
    ; --- Temporary vars ----
    BARtemp     VAR  WORD
    Remainder   VAR  WORD
    BARloop     VAR  BYTE
    LastCharset VAR  BYTE : LastCharset = 0
    Limit1      VAR  WORD
    GOTO overBAR                                   ; Skip over Subroutines
        ThreeBARS CON EXT
        TwoBARS   CON EXT
        OneBAR    CON EXT
        CharLoc3  CON EXT
        CharLoc2  CON EXT
        CharLoc1  CON EXT
     ifdef NEWHAVEN_DISPLAY
    ThreeBARS = 1                                ; Identify the Custom Characters
    TwoBARS   = 2
    OneBAR    = 3
    ThreeBARS = 0                                ; Identify the Custom Characters
    TwoBARS   = 1
    OneBAR    = 2
    CharLoc3 = 40h +(ThreeBARS*8)
    CharLoc2 = 40h +(TwoBARS*8)
    CharLoc1 = 40h +(OneBAR*8)
    lines  = 0x10000001                            ; Define the Styles
    boxed  = 0x10000002
    blocks = 0x10000003
    CharsetLines:
        LCDOut $FE,CharLoc3,REP $15\8                  ; Custom char 0 - 3 lines  |||
        LCDOut $FE,CharLoc2,REP $14\8                  ; Custom char 1 - 2 lines  ||
        LCDOut $FE,CharLoc1,REP $10\8                  ; Custom char 2 - 1 line   |
    CharsetBoxed:
        LCDOut $FE,CharLoc3,$1F,REP $15\6,$1F          ; III
        LCDOut $FE,CharLoc2,$1C,REP $14\6,$1C          ; II
        LCDOut $FE,CharLoc1,REP $10\8                  ; I
    CharsetBlocks:
        LCDOut $FE,CharLoc3,REP $1F\8
        LCDOut $FE,CharLoc2,REP $1C\8
    ; ----- Show the BAR graph -----------------------------------------------------
    ShowBAR:
        IF BAR_width = 0 then BARdone
        if LastCharset <> BAR_style then          ; If the Style has changed ?
            LastCharset = BAR_style
            SELECT CASE BAR_style                 ; Load the new custom chars
                CASE 1 : GOSUB CharsetLines
                CASE 2 : GOSUB CharsetBoxed
                CASE 3 : GOSUB CharsetBlocks
            END SELECT
    @ ifdef LCD4X20
        LOOKUP BAR_row,[$80,$80,$C0,$94,$D4],BARtemp
    @ else
        LOOKUP BAR_row,[$80,$80,$C0,$90,$D0],BARtemp
    @ endif
        LCDOUT $FE, BARtemp + BAR_col             ; Move cursor to start of the BAR
        BARtemp = BAR_value * BAR_width           ; calc the char position
        BARtemp = DIV32 BAR_range
        Remainder = R2
        For BARloop = 0 to BAR_width -1
            SELECT CASE BARtemp
                CASE IS > BARloop
                    LCDOUT ThreeBARS              ; send 3 bars    |||
                CASE IS < BARloop
                    LCDOUT " "                    ; clear to end of BARwidth
                CASE IS = BARloop
                    Limit1 = BAR_range * 6
                    Limit1 = DIV32 10
                    if Remainder >= Limit1 then
                        LCDOUT TwoBARS            ; send 2 bars    ||
                        Limit1 = BAR_range * 3
                        Limit1 = DIV32 10
                        if Remainder >= Limit1 then    ; 30%
                            LCDOUT OneBAR         ; send 1 bar     |
                            LCDOUT " "            ; no bars
            END SELECT
        NEXT BARloop
    BARdone:
    ; --- The main macro for creating BARgraphs ------------------------------------
    BARgraph  macro  Value, Row, Col, Width, Range, Style
        MOVE?CW    Range, _BAR_range              ; Range MUST be a constant
        MOVE?WW    Value, _BAR_value              ; Value MUST be a WORD variable
        if (Row < 5)                              ; Row is a constant
            MOVE?CB    Row,   _BAR_row
        else                                      ; Row is a variable
            MOVE?BB    Row,   _BAR_row
        if (Col < 16)                             ; Is Col a constant ?
            MOVE?CB    Col,   _BAR_col
        else                                      ; NO, it's a variable
            MOVE?BB    Col,   _BAR_col
        if (Width <= 40)
            MOVE?CB    Width, _BAR_width
            MOVE?BB    Width, _BAR_width
        if ((Style >= lines) & (Style <= blocks)) ; Is Style a valid constant ?
            MOVE?CB    Style, _BAR_style
        else                                      ; NO, treat it like a variable
            MOVE?BB    Style, _BAR_style
        L?CALL   _ShowBAR
    overBAR:
    Of course, more could be done to make this even more flexible, but this is at least a tidy way do deal with this particular problem.
    Last edited by SteveB; - 24th November 2012 at 02:28. Reason: added ending statement
  7. #207
    New Jersey
    I'm glad I was able to help.
    It doesn't matter where you put this statement. Top, bottom, side, back, inbetween, etc. It will work no matter it is.
  8. #208
    May 2006
    Del Rio, TX, USA
    Christopher,
    I wasn't slighting your contribution, sorry if it came across that way. I seriously don't think anybody would have figured it out without the testing you did (ok, maybe Darrel if he decided to take it on as a project). It is certainly a unique problem. My posts were both aimed at the community at large. Initially to aviod any confusion by a would be user that is less diligent than yourself. Then, to offer a more comprehensive solution that could be used as a substitute for the original include file. (I would have sent it to Darrel via PM initially for his approval, and possible change to the original file, but since he is a big-wig at ME now, he doesn't accept PMs anymore. )
    And yes, you are correct, that DEFINE can probably go anywhere and it will still work. (I was playing it safe due to limited time to write and test the code for errors while my 3 kids were playing sword-fighting in the living room with me ducking occasionally to avoid a head wound ). If Darrel is inclined to correct that statement via his Moderator powers, I've got no problem with that. I also missed coloring the second "CharLoc1" blue.
    Best Regards,
    New Jersey
    No worries. I like to be sarcastic and I'm difficult to offend. In my 7 years (on and off) this forum, it was the first time I was able to provide a contribution that may help other people.
  10. #210
    New Jersey
    Is there a way to modify the code to display from the right to the left? I've tried a number of different things but it doesn't work correctly.
  11. #211
    Let the display do the hard work by using the Right to Left "Entry Mode".
    Then just change the custom characters.
    No changes are required to the include file.
    X  VAR WORD
    ;----[Initialize bargraph]------------------------------------------------------
    X = 0
    @   BARgraph  _X,   1,   1, 20,   512,  lines
        LCDOut $FE,$48,REP $15\8                  ; Custom char 1 - 1 line     |
        LCDOut $FE,$50,REP $05\8                  ; Custom char 2 - 2 lines   ||
        LCDOut $FE,$58,REP $01\8                  ; Custom char 3 - 3 lines  |||
    ;----[Main Program Loop]--------------------------------------------------------
    MainLoop:
        FOR X=1 TO 512
            PAUSE 10
            LCDOUT $FE,$94,DEC X,"    "
            LCDOUT $FE,$04  ; Set Entry mode Right to Left
    '@      BARgraph   Value, Row, Col, Width, Range, Style
    @       BARgraph      _X,   1,  20,    20,   512,  lines
            LCDOUT $FE,$06  ; Restore Entry mode Left to Right
        NEXT X
    GOTO MAINLOOP
    Of course, I'm assuming the Newhaven display can actually do that.
    Normal LCD's can.
    May 2006
    Del Rio, TX, USA
    Darrel, I know you know what happens when one assumes.
  13. #213
    New Jersey
    Are Newhaven LCD's the redheaded step children of LCD's? I've never had a problem with them. Then again, I don't make many projects that have displays and if I do need one I don't look at the manufacturer when ordering one. If I was using an LCD, I'd go with whoever is the cheapest. Regarding OLED, it's the first time I've used one and the Newhaven OLED's are awesome. I am making a product for a car and the screen doesn't get washed out in the light and it's not too bright at night time. It's perfect!
    Anyhow, thanks for the help. I spent a little more than 6 hours trying to get it but you pushed the easy button! Regarding your comment, the display WILL show the bargraph but for some reason you have to modify this line:
    To this:
    BARgraph      _X,   1,  19,    20,   512,  lines
    If you don't modify it, the bargraph will sit in column one with three bars displayed while the number counts from 1 to 512. I guess you can add this to the "uniqueness" of Newhaven displays!
  14. #214
    May 2006
    Del Rio, TX, USA
    So, I know that Darrel provided a nice hardware solution. But, like a dog with a new bone, I wanted to work out a software solution.
    When using the modified include file, the only change needed in the main program is an additional parameter to @ BARgraph:
    @ BARgraph Value, Row, Col, Width, Range, Style, RtoL
    0 = Left to Right, 1 = Right to Left
    Here is the code, the file is below:
    '*  Name    : LCDbar_INC_MOD2.bas                               *
    '*          : (vs. 0-2).                                        *
    '*          : following define statement:                       *
    '* Modified : By SteveB on 11/27/2012                           *
    '*          : This modification introduces the ability to       *
    '*          : display the bargraph from Right-to-Left.          *
    ;@   BARgraph   Value, Row, Col, Width, Range, Style, RtoL
    ;Value: The Value of the BARgraph  (0 to Range).If Range = 100 and Value is 50, then
    ;          half of the BARgraph will be filled in.   Value MUST be a WORD sized variableą
    ;Row: LCD Row to place the BARgraph (1 to 4)   can be either a constant or a
    ;          variableą.
    ;Col: LCD Column to place the BARgraph (0 to LCDsize˛ - 1)   can be either a constant
    ;          or a variableą.
    ;Width: Width of the BARgraph in charaters. (1 to LCDsize˛)   can be either a constant
    ;          or a variableą.
    ;Range: The "full-scale" range of the BARgraph  (0 to 32768) MUST be a constant.
    ;          Variables will not work here.
    ;Style: Selects which Style will be used for the BARgraph  (lines, boxed, blocks)   can
    ;          be either a constant or a variableą.
    ;RtoL: MUST be a constant
    ;	 When set to 0, Bar will display Left-to-Right
    ;	 When set to 1, Bar will display Right-to-Left
    ;Note ą - Variables must be preceeded with a
    ;             underscore.   ie.  _Temperature
    ;Note ˛ - LCDsize is the number of Chars in 1 line of
    ;             the LCD, for "4x16" it's 16
    ;                                              ;                        default
    BAR_RtoL    VAR  BYTE : BAR_RtoL = 0
    BARtemp     VAR  WORD
    Remainder   VAR  WORD
    BARloop     VAR  BYTE
    LastRtoL    VAR  BYTE : LastRtoL = 0
    Limit1      VAR  WORD
    ThreeBARS CON EXT                              ; Identify the Custom Characters
    TwoBARS   CON EXT
    OneBAR    CON EXT
    CharLoc3  CON EXT
    CharLoc2  CON EXT
    CharLoc1  CON EXT
    ThreeBARS = 1
    TwoBARS   = 2
    OneBAR    = 3
    ThreeBARS = 0
    TwoBARS   = 1
    OneBAR    = 2
    boxed  = 0x10000002
    blocks = 0x10000003
    CharsetLines:
        LCDOut $FE,CharLoc3,REP $15\9                 ; Custom char 3 lines  |||
        IF BAR_Rtol = 0 THEN
            LCDOut $FE,CharLoc2,REP $14\9             ; Custom char 2 lines  ||
            LCDOut $FE,CharLoc1,REP $10\9             ; Custom char 1 line   |
            LCDOut $FE,CharLoc2,REP $05\9             ; Custom char 2 lines   ||
            LCDOut $FE,CharLoc1,REP $01\9             ; Custom char 1 line     |
    CharsetBoxed:
        LCDOut $FE,CharLoc3,$1F,REP $15\7,$1F         ; III
            LCDOut $FE,CharLoc2,$1C,REP $14\7,$1C     ; II
            LCDOut $FE,CharLoc1,REP $10\9             ; I
            LCDOut $FE,CharLoc2,$07,REP $05\7,$07     ;  II
            LCDOut $FE,CharLoc1,REP $01\9             ;   I
    CharsetBlocks:
        LCDOut $FE,CharLoc3,REP $1F\9
            LCDOut $FE,CharLoc2,REP $1C\9
            LCDOut $FE,CharLoc2,REP $07\9
    ShowBAR:
        if LastCharset <> BAR_style OR LastRtoL <> BAR_RtoL then ; If for change
            LastRtoL = BAR_RtoL
            END SELECT
    @ ifdef LCD4X20
    @ else
    @ endif
        Remainder = R2
        IF BAR_RtoL = 0 THEN
            LCDOUT REP ThreeBARS\(BARtemp)                 ; send 3 bars
            IF BARtemp < BAR_width THEN
                LCDOUT REP " "\(BAR_width - BARtemp - 1)   ; Clear up to BARtemp-1
            Limit1 = DIV32 10
                Limit1 = DIV32 10
                LCDOUT REP " "\(BAR_width - BARtemp - 1)   ; clear till the end
    BARdone:
    BARgraph  macro  Value, Row, Col, Width, Range, Style, RtoL
        if (Width <= 40)
        MOVE?CB     RtoL, _BAR_RtoL
        L?CALL   _ShowBAR
    overBAR:
    LCDbar_INC_MOD2.bas.txt
  15. #215
    May 2006
    Del Rio, TX, USA
    Here's some sample code (no fancy animations):
    'DEFINE NEWHAVEN_DISPLAY 1   'uncomment if needed
    INCLUDE "LCDbar_INC_MOD2.bas"
    wCounter VAR WORD
        LCDOUT $FE, $01
        PAUSE 100
    MAIN:
        FOR wCounter = 0 to 100
            PAUSE 50
            LCDOUT $FE, $80, DEC3 wCounter
        @   BARgraph  _wCounter,   1,  5,    13,   100, lines, 0
        NEXT wCounter
        FOR wCounter = 100 to 0 STEP -1
            PAUSE 50
        NEXT wCounter
    GOTO MAIN
  16. #216
    Nicely done Steve.
    It works great.
    May 2006
    Del Rio, TX, USA
    Thanks Darrel.
  18. #218
    New Jersey
    Works perfectly! Awesome job!
  19. #219
    Dec 2008
    Ploiesti, ROMANIA
    I saw a schematic of volt-ampermeter, with PIC, with a nice animation ... Two different scale on the same row !!! Using "empty boxes" for volts and "filled boxes" for ampers ...the number of boxes varies proportionally with the parameter (volts; ampers).
    Can this be done in PBP ?! Thanks !
  20. #220
    Quote Originally Posted by fratello View Post
    Yes it can ...
    Custom Characters ...
      LCDOUT  $FE,$48,$00,$00,$00,$00,$1F,$1F,$1F,$00  ' Cust Char #1
      LCDOUT  $FE,$50,$1F,$11,$1F,$00,$00,$00,$00,$00  ' Cust Char #2
      LCDOUT  $FE,$58,$1F,$11,$1F,$00,$1F,$1F,$1F,$00  ' Cust Char #3
    Dec 2008
    Ploiesti, ROMANIA
    Wow ! Amazing ! THANK YOU, Mr.Darrel !
    I will try to figure out how displaying ...
  22. #222
    Dec 2008
    Ploiesti, ROMANIA
    Let's say I read maximum 50 volts and maximum 5 ampers ; so one "empty box" = 5 volts and one "filled box" = 0.5 ampers.
    It's this "pseudo" code correct ?!
    for y=9 to 0 step -1
    if volts >= (y*5) then
        if ampers >= (y * 1/2) then
    char = 3
    LCDOUT $FE, $80, char,char,char,char,char,char,char,char,char,char
    Endif
    Endif
    I'm sure it's another way, much easiers, but I have -till now- no ideea ...
  23. #223
    May 2006
    Del Rio, TX, USA
    Untested, likely needs some debugging, but at least the methodology should be clear.
    LCDPos	VAR BYTE
    volts	VAR WORD	' 0 to 500 representing 0 to 50.0 Volts
    Amps	VAR BYTE	' 0 to 50 representing 0 to 5.0 Amps
    Char	VAR BYTE
    FOR LCDPos = 0 TO 9
    	IF Volts / 50 >= LCDPos + 1 THEN	' Fill in Volt Block
    		IF Amps / 5 >= LCDPos + 1 THEN		' Fill in Volt + Amp Block
    			Char = 3
    		ELSE					' Fill in Volt Block Only
    			Char = 2
    	ELSE					' Don't Fill in Volt Block
    		IF Amps / 5 >= LCDPos + 1 THEN		' Fill in Amp Block only
    			Char = 1
    		ELSE					' Fill with Space
    			Char = 32
    	LCDOUT 	$FE, $80 + LCDPos, Char
    NEXT LCDPos
  24. #224
    Dec 2008
    Ploiesti, ROMANIA
    Thank You, I will post the results !
  25. #225
    Aug 2013
    In this code what does "Rep" do? I'm using it with the Proton IDE Basic Compiler.
    It works OK, but I am curious as I can't find any reference to "Rep" in the documentation.
    Is it a repeat function?
    Thanks, Mark
    Print $FE, CGRAM, Rep $0\8,$0, Rep $10\6,$0,$0, Rep $14\6,$0,$0, Rep $15\6,$0,$0
    Warnings = OFF
    Byte_Math = On
    BARS = (TOP_BAR Min MAXBAR) / 3 ; One full bar for each 3 graph units
    BALANCE = (TOP_BAR Min MAXBAR) //3 ; Balance is the remainder after a division by 3
    BALF = BALANCE Min 1
    Print At 1,1, Dec3 POWERMAX, "W "
    Print At 1,6, Rep FULLBAR\BARS,Rep (BALANCE + BASEBAR)\BALF,Rep " "\B_WDTH - (BARS + BALF)
    BARS = (LOW_BAR Min MAXBAR) / 3 ; One full bar for each 3 graph units
    BALANCE = (LOW_BAR Min MAXBAR) //3 ; Balance is the remainder after a division by 3
  26. #226
    You are on the wrong forum. Here is MELABS PicBasic Forum.
    But anyway, REP is just repeating the next character \times
    Aug 2003
    Hi, DON
    Just turn your LCD 90° cckw !!!
    Did a vertical graphing tachometer over time with a single custom char (far right in the video).
    Just got to matrix rotate the byte and shift every byte in the custom char every frame to make room for the next vertical byte.
    (this one has odometer effect on the elapsed timer as well
  28. #228
    Hi Art. It is awesome! Really nice effect.
    Sao Paulo - Brazil
    Hi Art !
    nice idea for the tachometer.
    I have an old project, where I´m already using 8 custom chars to show darrel´s bargraph, and other "compressed characters, like "Km/l" , "L/h".
    Is it possible to re-use the custom char to show the odometer efect and this nice tachometer or this is not possible ?
    Is your code for the tachometer complicated ?
    Thank you.
    Sérgio
  30. #230
    Aug 2003
    I'll post it go in it's own thread in a little bit.
    The tach is interrupt driven, display is PBP.
    I'm close to finishing something much nicer
  31. #231
    Sao Paulo - Brazil
    Hi Art,
    Thank you very much for your reply !
    I Will wait for your post.
    My best regards.
    Sérgio
  32. #232
    Aug 2003
    Hi srspinho,
    Unfortunately I have lost that code
    In the end, for that project, I ditched both the graphing tachometer,
    and the rolling odometer effect for the time display.
    They both looked good on the desk where the project spent a couple of months,
    but in the car, they both turned out to be a terrible idea.
    I could see the peak on the tachometer graph, but not tell if it was the current
    reading without looking hard, and the same with the elapsed time.
    I went back to a plain vertical bargraph for the tachometer:
    I do still have current code for the project that I wouldn't otherwise mind sharing entirely,
    but I would mind spending the time making sense of it where it was not written for others.
    It is only a collection of things available here, or substitutes for them done myself.
    I did my own asm interrupts for example, but DT's interrupts do exactly the same thing.
    I didn't read this correctly.
    No, it is only possible to display eight at a time, you can only change the content of those eight locations an unlimited number of times.
    otherwise it would be a full graphics LCD. THe elapsed timer in this one is only using six of them, the tach uses one, and there's a spare.
  33. #233
    Sao Paulo - Brazil
    Thank you Art !
    I think I Will try your 2x16 graphic lib .
    Regards.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
