LCD BARgraphs
Results 1 to 40 of 233
Thread: LCD BARgraphs
Threaded View
    Default LCD BARgraphs
    LCD BARgraphs
    LCDbar_INC.bas
    is an Include file that makes it easy to create BARgraphs on your LCD display.
    Features:
    • Can be placed anywhere on the screen.
    • Can be any width (whole characters)
    • Can be scaled anywhere between 0 and 32768.
    • Three styles to choose from.  {lines, boxed, blocks}
    • Just 1 Command does it all. (Well, sort of)
    Click here for Larger Video (225kbps)
    @   BARgraph   Value, Row, Col, Width, Range, Style
    Value: The Value of the BARgraph  (0 to Range).If Range = 100 and Value is 50, then
              half of the BARgraph will be filled in.   Value MUST be a WORD sized variable¹
    Row: LCD Row to place the BARgraph (1 to 4)   can be either a constant or a
              variable¹.
    Col: LCD Column to place the BARgraph (0 to LCDsize² - 1)   can be either a constant
              or a variable¹.
    Width: Width of the BARgraph in charaters. (1 to LCDsize²)   can be either a constant
              or a variable¹.
    Range: The "full-scale" range of the BARgraph  (0 to 32768) MUST be a constant.
              Variables will not work here.
    Style: Selects which Style will be used for the BARgraph  (lines, boxed, blocks)   can
              be either a constant or a variable¹.
    Note ¹ - Variables must be preceeded with a
                 underscore.   ie.  _Temperature
    Note ² - LCDsize is the number of Chars in 1 line of
                 the LCD, for "4x16" it's 16
    Added 10/18/05 - If using a 4x20 display, you can use this define to let the program know the addressing is different.   Thanks, CocaColaKid!
    DEFINE  LCD4X20  1
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
    Last Post: - 27th June 2007, 00:07
  5. LCD will not start
