12F683 Comparator Problems
Results 1 to 4 of 4
    really far of what you need but here's an example with a 12f675 i did many months ago using the internal comparator
    @ __config _INTRC_OSC_NOCLKOUT & _MCLRE_OFF  ;config fuse
    TRISIO = %11001111 ;GPIO.4, GPIO.5 as output
    CMCON=%00000010 ;COUT=1 when Vin+(GPIO.0) > Vin- (GPIO.1)
    				;comparator mode :comparator without output
    ANSEL=0 ;turn off analog to digital
    Clip     var   GPIO.4
    Normal   var   GPIO.5
    Speaker  var   byte
    start:
    	  speaker=CMCON.6 ;read from internal comparator
          Select case speaker
                 case 0
                      clip=0
                      normal=1
                 case 1
                      clip=1
                      normal=0
                      Clip=0
          end select
    	  goto start
    morethanenuf's Avatar
    morethanenuf Guest
    Thanks for the help. I understand how your code works, but I still can't get the comparator to work as far as I can tell. All I'm trying to do now is use 2 pots as the analog inputs Vin+ and Vin- and use COUT to turn an led on and off. Is there a drive problem with the comparator? Do I have to use the internal output as a signal to drive a separate pin HIGH or LOW?
    By looking the datasheet, the comparator will be GP2 and must be set as digital and can sink/source +/- 25mA
  1. 12F683 - Pin1 not working
    Last Post: - 8th February 2014, 18:38
  2. Setting up a 12F683 to run at 20 Mhz
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 03:46
  3. 12F683 Programmer
    By Red_Stafford in forum Schematics
    Last Post: - 2nd October 2008, 22:44
  4. 12F683 HPWM Usage
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 03:16
  5. 16f677a to 12f683
    Last Post: - 25th July 2007, 07:16
