code conversion
Results 1 to 20 of 20
Thread: code conversion
    Sep 2005
    Malaysia
    Default 3 motor robot
    The book is called PIC robotics by john iovine. Am interested in your 3 motor robot. Where can i have a look at that project???
    -·=»‡«=·- saturnX -·=»‡«=·-
    Nov 2004
    Saskatchewan Canada
    Thanks. I'll check into that book.
    The book I bought is called "Insectronics" by Karl Williams.
    Web site: http://www.thinkbotics.com/
    I haven't built it yet, don't know if I ever will because I'm holding out for something with a bit more in the way of degrees of freedom.
    I looked at your code here too and as much as I wouldn't genrally disagree with Mister E (who is 1000X smarter than I) I don't think you can just make a couple changes to get it to work in PicBasic. The ENDIF statement alone would grind it to a halt so you are lucky to have found someone who can compile it for you with the Pro version.
    Bart
    Sep 2005
    Malaysia
    haha you know what though i managed to get a copy of the pro version last minute from a friend of mine. thank goodness! saved me a lot of work. lol... thanks for the link too. will look into it later on.
    Raycher's Avatar
    Raycher Guest
    Hi, the code were used for a insec bot. I used the book called "Insectronics" by Karl Williams to built a six legged insec - works pretty well once one can program the chip.
    r
    Sep 2005
    Malaysia
    i guess i have to go get the book huh bartman... lol... thanks raycher for the post
    Nov 2004
    Saskatchewan Canada
    I guess if you want it you'll need to buy it, yes. I don't want to sell or give mine away as it has useful information that may come in handy.
    I ordered the book you mentioned from Amazon. Came to $20.00 with shipping which seemed pretty reasonable.
    Bart
    Sep 2005
    Malaysia
    that isn't a too bad price i guess. have fun with it when you get the book. the problem about the book is that i find the author some times forget that there are newbies to the whole PIC programming and basic robotics so some of his projects seem a little way advance. plus when i first got the book and read the first few chapters i was under the impression that the projects would be written for PICBasic Compilers along with the Pro Compilers. when i finally purchased PicBasic i couldn't compile his codes for the walking robot which were written for the pro versions. i was new then some 20 posts ago Strange thing was the earlier projects before the walking robot had both basic and pro version of codes.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
