code conversion
Results 1 to 20 of 20
Thread: code conversion
    Nov 2004
    Saskatchewan Canada
    I'd be interested in knowing the name and author of this book. I have a book for a walking robot that uses just 3 servos. I'm interested in the 8 servo one.
    Bart
    Sep 2005
    Malaysia
    Default 3 motor robot
    The book is called PIC robotics by john iovine. Am interested in your 3 motor robot. Where can i have a look at that project???
    -·=»‡«=·- saturnX -·=»‡«=·-
    Nov 2004
    Saskatchewan Canada
    Thanks. I'll check into that book.
    The book I bought is called "Insectronics" by Karl Williams.
    Web site: http://www.thinkbotics.com/
    I haven't built it yet, don't know if I ever will because I'm holding out for something with a bit more in the way of degrees of freedom.
    I looked at your code here too and as much as I wouldn't genrally disagree with Mister E (who is 1000X smarter than I) I don't think you can just make a couple changes to get it to work in PicBasic. The ENDIF statement alone would grind it to a halt so you are lucky to have found someone who can compile it for you with the Pro version.
    Bart
    Sep 2005
    Malaysia
    haha you know what though i managed to get a copy of the pro version last minute from a friend of mine. thank goodness! saved me a lot of work. lol... thanks for the link too. will look into it later on.
    Raycher's Avatar
    Raycher Guest
    Hi, the code were used for a insec bot. I used the book called "Insectronics" by Karl Williams to built a six legged insec - works pretty well once one can program the chip.
    r
    Sep 2005
    Malaysia
    i guess i have to go get the book huh bartman... lol... thanks raycher for the post
    Nov 2004
    Saskatchewan Canada
    I guess if you want it you'll need to buy it, yes. I don't want to sell or give mine away as it has useful information that may come in handy.
    I ordered the book you mentioned from Amazon. Came to $20.00 with shipping which seemed pretty reasonable.
    Bart
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
