code conversion
Results 1 to 20 of 20
Thread: code conversion
    Sep 2005
    Malaysia
    Smile thanks..
    hi steve.. thanks for the update.... i forgot to update the post here but i managed to track down a copy of PICBasic Pro from a friend of mine and got him to compile the program for me. lol solves the problem and having to change the codes. Thanks anyways... oh any idea where i could find a virtual breadboard? not the one from http://www.muvium.com/ (previously virtualbreadboard.com). I came across a few versions written in java but does not have the 16F84 chip. anything that can help?
    Some will hate me but i assume my words 100%. I hate Virtual stuff as they never give the truth... well maybe close to but i'd and i'll never use and trust that kind of stuff. I still prefer spending time to build a real one... yeah i have that old manner to work.
    SO probably ISIS, VSM, PROTEUS( i can't remind wich is wich) from Labcenter could help.. see info on the link bellow
    http://www.labcenter.co.uk/
    Some said it's a great tool... can't commernt on. I have it, but never tested and i'll probably never.
    Sorry!
    Nov 2004
    Saskatchewan Canada
    I'd be interested in knowing the name and author of this book. I have a book for a walking robot that uses just 3 servos. I'm interested in the 8 servo one.
    Bart
    Sep 2005
    Malaysia
    Default 3 motor robot
    The book is called PIC robotics by john iovine. Am interested in your 3 motor robot. Where can i have a look at that project???
    -·=»‡«=·- saturnX -·=»‡«=·-
    Nov 2004
    Saskatchewan Canada
    Thanks. I'll check into that book.
    The book I bought is called "Insectronics" by Karl Williams.
    Web site: http://www.thinkbotics.com/
    I haven't built it yet, don't know if I ever will because I'm holding out for something with a bit more in the way of degrees of freedom.
    I looked at your code here too and as much as I wouldn't genrally disagree with Mister E (who is 1000X smarter than I) I don't think you can just make a couple changes to get it to work in PicBasic. The ENDIF statement alone would grind it to a halt so you are lucky to have found someone who can compile it for you with the Pro version.
    Bart
    Sep 2005
    Malaysia
    haha you know what though i managed to get a copy of the pro version last minute from a friend of mine. thank goodness! saved me a lot of work. lol... thanks for the link too. will look into it later on.
    Raycher's Avatar
    Raycher Guest
    Hi, the code were used for a insec bot. I used the book called "Insectronics" by Karl Williams to built a six legged insec - works pretty well once one can program the chip.
    r
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
