Analog pins for digital input
Results 1 to 5 of 5
    i never tested the above suggestion but it can work. But for safety sake i will turn them to digital.
    Another solution...use ADCIN to read the pin.
    [html]
    If result<XYZ => pin is LOW
    if result>ABC => pin is HIGH.
    [/html]
    That will allow to determine your own HIGH/LOW threshold.
    Just an idea.
    Sep 2005
    Campbell, CA
    I realize that I could just do a conversion to determine the pin's state, but I need to sit in a loop and look for a really short toggle.
    The reason I have to configure it as analog is that the signal is connected to AN1, and I need to configure AN2 & AN3 as analog. The circuit is already built and I can't change the wiring.
    I think the best solution is to do what Melanie suggested and configure the port as digital, read the pin, convert to analog, read channels 2&3, and switch back to digital.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Analog input on 18f252
    By kiteman in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 09:34
  3. Analog Input on PIC16F88
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 6th May 2008, 23:49
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. How can i control pic input pins order?
    By tanero in forum mel PIC BASIC Pro
    Last Post: - 18th August 2005, 13:46
