Analog pins for digital input
Results 1 to 5 of 5
    As long as you only need to read digital "input", you can leave the pin configured as analog.
    I believe TTL logic high (when using a 5 volt supply) is 2V.
    So, just read your analog input and if the voltage is higher than 2V, set a logic flag high. If it's less than 2V, set the flag low.
    That being said, you could just reconfigure the pin as Melanie suggested.
    However, it sounds like you want to leave it configured as analog for some reason.
    I'd be curious to see if you could simply read the pin's input value (not the ADC value) when it's configured as analog. It would be interesting if it registered as a 1 when the voltage was greater than 2V. You should try it.
    Cheers!
    ---> picnaut
    i never tested the above suggestion but it can work. But for safety sake i will turn them to digital.
    Another solution...use ADCIN to read the pin.
    [html]
    If result<XYZ => pin is LOW
    if result>ABC => pin is HIGH.
    [/html]
    That will allow to determine your own HIGH/LOW threshold.
    Just an idea.
    Sep 2005
    Campbell, CA
    I realize that I could just do a conversion to determine the pin's state, but I need to sit in a loop and look for a really short toggle.
    The reason I have to configure it as analog is that the signal is connected to AN1, and I need to configure AN2 & AN3 as analog. The circuit is already built and I can't change the wiring.
    I think the best solution is to do what Melanie suggested and configure the port as digital, read the pin, convert to analog, read channels 2&3, and switch back to digital.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Analog input on 18f252
    By kiteman in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 09:34
  3. Analog Input on PIC16F88
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 6th May 2008, 23:49
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. How can i control pic input pins order?
    By tanero in forum mel PIC BASIC Pro
    Last Post: - 18th August 2005, 13:46
