hopefully simple code
Results 1 to 4 of 4
    Counting is counting, whether it's Binary, Decimal, Hexadecimal or in Latin. It's how you finally OUTPUT it that counts. Here is a simple program that will count (add one) each time your Button is pressed, and output the status in BINARY to an array of LEDs.
    Consider the following Program and circuit.
    You have a PushButton connected between PortA.0 and Vss. A pull-up Resistor (say 10K) is connected between PortA.0 and Vdd. That means the pin is usually High (Logic 1) when NOT pressed, and goes Low (Logic Zero) when pressed.
    PortB has an LED on each pin connected between the pin and Vss via a Resistor (one for each LED), lets say 330R.
    The program variable CounterA is incremented once each time the PushButton is pressed, it's status is then sent to PortB so you can see it happen. The Pause is there to debounce the Pushbutton from giving you multiple counts on one press. The While-Wend pair is there to ensure you lift your finger off the button before a new count is registered. The rest you can figure yourself between the PICBasic manual and the Datasheet.
    	'	Program Hardware Defines
    	PushButton var PortA.0
    	LEDArray var PortB
    	'	Program software Defines
    	CounterA var Byte
    	'	Initialise Program
    	TRISA=%11111111
    	TRISB=%00000000
    	CounterA=0
    	'	Main Program Loop
    Loop:
    	If PushButton=0 then
    		CounterA=CounterA+1
    		LEDArray=CounterA
    		Pause 10
    		While Pushbutton=0:Wend
    	Goto Loop
    Sep 2005
    Wink many thanks
    the program you sent me work perfect.
    greatly appreciated.
    hope to become a lot smarter visiting your forum.
    thanks again for an extremely quick response and for thinking about us "newbies"
    dominic
    Be confident Dominic. I get a big part of my knowledge here by trying to help other with their specific problem.
    Have fun and good luck!
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
  2. what's wrong 16F877A simple code?
    Last Post: - 30th October 2009, 02:11
  3. Manchester coding/decoding Code help
    By financecatalyst in forum Code Examples
    Last Post: - 25th August 2009, 20:05
  4. Simple Wireless Communication
    By jhorsburgh in forum General
    Last Post: - 27th March 2008, 12:02
  5. PIC18F4525 & LCD simple code problem
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 17:29
