is hserin slow?
Results 1 to 8 of 8
Thread: is hserin slow?
    Jun 2005
    Smile
    Thanks Steve!
    Is RCREG 2 bytes?
    I only have 1 byte to send, Should I always send 2 bytes
    and always read 2 bytes?
    Mark
    I think that RCREG can only "hold" 2 bytes.
    If you don't retrieve your data before that 3rd byte comes along, you get an overrun or something. It probably just kicks the first byte it received "off the end".
    ---> picnaut
    YUP! RCREG is a 2 byte buffer. This help to miss character.
    You don't need to read always 2 bytes ... well yes and no. Just make a check if the RCREG is now empty will suffice.
    and you just need to send 1 bytes at the time as TXREG is a single 1 byte register.
    HTH
    Aug 2005
    Here is a couple attached demo programs that might help,written for the 16F877.Modify for you needs.One uses the on interrupt command and the other the interrupt flag.
    Jun 2005
    Thumbs up
    Thank You all!
    I was frustrated and a little weary but your suggestions were
    timely and very helpful. My serial communications are working now.
    Reading RCIF & RCREG appear much faster than HSERIN.
    Mark
    It's like many built-in function.
    HSERIN/HSEROUT
    HPWM
    ADCIN
    are some in the list. When you need for speed, the best way is still acess the internal register. It also produce tighter code. Built-in function are great when you don't want to break your nuts with data handling and ... and ... and.. well you know what i mean
  1. Hserin with Instant Interrupts.
    By ronjodu in forum Serial
    Last Post: - 30th December 2014, 21:17
  2. HserIn and Interrupts
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 08:15
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 01:38
  4. Hserin not working...
    By robert0 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 13:25
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 16:42
