LCD + bar graph
Results 1 to 14 of 14
Thread: LCD + bar graph
    Default Take a look here
    I saw this a couple of years ago...
    http://www.parallax.com/dl/docs/cols...l1/col/nv8.pdf
    Brgds Roy
    Jun 2005
    Wisconsin
    Not quite what I was thinking of. I'm hoping for something along the lines of a progress bar.
    Jun 2005
    Wisconsin
    Hi Ben,
    Probably too late for you, but in case what you found didn't work out ...
    LCD BARgraphs
    http://www.picbasic.co.uk/forum/showthread.php?p=12475
    Martin_Nissen's Avatar
    Martin_Nissen Guest
    Question
    Quote Originally Posted by Darrel Taylor
    Hi Ben,
    LCD BARgraphs
    I can't get my program compiled when using your file.. It says that my VALUE (in this case, WRD1) is an illegal opcode - With and without _ in front of the word
    Hi Martin,
    Make sure there's a space after the @ symbol, and the CASE matches EXACTLY.
    Other than that, I would need to see your code.
    Martin_Nissen Guest
    Hi Martin,
    Must be because it doesn't work in the compiler i'm using then..
    Smile
    I have it working fine. Just use the example and modifiy it to your application.
    Nice job Darrel.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
