Using 16f676 with comms
Results 1 to 10 of 10
    Default Using Async Comms? Then fit a Resonator or Xtal!
    In case anyone's missed it in a hundred or so previous threads...
    You are NEVER going to get repeatable reliable asynchronous communications at any speed without an xtal or resonator.
    You might strike lucky, or you might tear your hair out chasing your tail all because your timing is out of spec.
    I've written example code at 300 baud and posted them on this forum in great confidence only to have the code fail for someone somewhere. Async comms is just plain unreliable on internal or RC oscillators.
    I have an application which uses a 12F675 (internal Oscillator factory calibrated) which is little more than an Alarm Beeper. It's important to hit the resonant frequency of the Piezo for maximum sound. Now the Piezo is quite tollerant... it likes 4kHz, but is happy from 3.8kHz thru 4.2kHz. Out of every batch of 100 we build, there's always two or three PICs that don't make the grade with the Factory Cal. Now that's a dumb beeper application - and here you want precision async timing with a Factory OSCAL value?
    Sep 2005
    Dayton, Ohio
    Thanks Melanie,
    You may have just saved me a few days (or weeks) of frustration. I am reading this thread only 12 hours after sending in my PCB designs for fabrication. After months of design, redesign, double-check, triple-check, I now realize I WILL need a xtal for the bootloader and PC serial comms. (I had really hoped to get away with INTOSC on the PIC18F2525 and use those I/Os for other tasks...oh well).
    LUCKILY.......I DID include the pads/traces for a xtal and caps....just in case......
    I might try the INTOSC, but only AFTER I get it working with the xtal.
    regards,
    Jim
    Jim Robertson
    "MilesTag" DIY Lasertag
    www.lasertagparts.com/mtdesign.htm
    Dayton, Ohio
    Feb 2004
    Germany
    Quote Originally Posted by Melanie
    ...I have an application which uses a 12F675 (internal Oscillator factory calibrated) which is little more than an Alarm Beeper. It's important to hit the resonant frequency of the Piezo for maximum sound. Now the Piezo is quite tollerant... it likes 4kHz, but is happy from 3.8kHz thru 4.2kHz. Out of every batch of 100 we build, there's always two or three PICs that don't make the grade with the Factory Cal. Now that's a dumb beeper application - and here you want precision async timing with a Factory OSCAL value?
    I have several 12F675's running in an NMEA application @4800 Baud on INTOSC.
    They run absolutely reliable, but to achieve this you have got to finetune OSCCAL on every single PIC.
    Accounting for the time this finetuning takes, I would never do this again.
    Today I do not even use resonators on applications where serial comms are involved,
    all my never designs include a crystal and two caps.
    At the end this is the less expensive solution since it doesn't require any calibration.
    regards
    Ralph
    Sep 2003
    INDIA
    Default Need to redesign !
    Thank you folks. I guess , I have to redesign the board using 16F72 IC.
    Hence forth I shall always remember to use a Xtal where necessary.
    regards
    Charudatt
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 17:39
  2. PIC12F675 comms issues
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 25th March 2007, 04:24
  3. Remote comms
    By thirsty in forum Serial
    Last Post: - 23rd June 2006, 15:42
  4. Pic to Pc Comms
    By Darrenmac in forum General
    Last Post: - 21st May 2005, 01:44
  5. USB comms
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 17:14
