Word to nibbles
Results 1 to 13 of 13
Thread: Word to nibbles
    Gauge Guy's Avatar
    Gauge Guy Guest
    Thumbs up Interesting development
    I remed out most of the code except the code containing the shifts. and started compiling. all went well until I unremed the following line:
    SEROUT PORTA.3,BRate,[32,Leader,#DataOut[5],#DataOut[4],#DataOut[3],#DataOut[2],#DataOut[1],10]
    then the error occurred.
    If I rem out all lines containing >> the above line compiles fine. If I rem out the line above (SEROUT PORTA.3 ... )the >> lines compile fine. If I change the above line to:
    SEROUT PORTA.3,BRate,[32,Leader,DataOut[5],DataOut[4],#DataOut[3],#DataOut[2],#DataOut[1],10]
    (thus removing the pound sign (#))
    Everything compiles fine.
    WIRD WIRD WEIRD can't confirm it here...
    what about if you split your SEROUT statement in two like..
    SEROUT PORTA.3,BRate,[32,Leader,#DataOut[5],#DataOut[4]]
    SEROUT PORTA.3,BRate,[#DataOut[3],#DataOut[2],#DataOut[1],10]
    or in a multiple line like
    SEROUT PORTA.3,BRate,[32,Leader,#DataOut[5],_
                          #DataOut[4],#DataOut[3],_
    the little thing that could do... i said could, if DataOut is a word size variable BUT i tried it also... works for me.
    BTW there's certainely somebody here or at MELABS who know why... over for me
    PBP offers pretty limited support for the 12-bit core.
    Calls and computed jumps can only be made to the first half (256 words) of any code page on the 12-bit core with PBP due to the meager resources on the 12-bit core.
    And, all PBP library routines have to squeeze into the 1st page, so it's tough to do much with PBP on a 12-bit core unless you're pretty creative.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    mmm now that make sense to me. So as i suggest before, trying to compile with another PIC would have solved the problem.. well if a 14 or 16 bit core where choose of course.
    Thanks Bruce for the neat and deep explanation.
    Gauge Guy's Avatar
    Gauge Guy Guest
    Smile Thanks
    Thanks to you all for your input, I think the mystery is solved. On my next project, I'll remember the limitations of the 12 bit core.
  1. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  5. calculation problem
    Last Post: - 31st March 2006, 16:23
