What memory is used for DATA @X, LONG $XXXXXX
Results 1 to 3 of 3
    Default Re: What memory is used for DATA @X, LONG $XXXXXX
    If you write a LONG to EEPROM it will occupy 4 bytes or "locations". So if your LONG starts at 0 the next free byte/location will be at adress 4.
    To be honest I'm not sure about the "order", ie little vs big endian but that's easy enough to test.
    Jan 2006
    Istanbul
    This should give you some idea how it is orginized.
    It explains itself. I captured the values 4 times, and the picture shows all 4 values.
    LongVal var long
    ByteVal0 var byte
    ByteVal1 var byte
    ByteVal2 var byte
    ByteVal3 var byte
    Test:
    '%00000000 00000000 00000000 00000001
    '%00000000 00000000 00000001 00000000
    '%00000000 00000001 00000000 00000000
    '%00000001 00000000 00000000 00000000
        longval = %00000000000000000000000000000001  '32-bit value.
        write 0, long longval
        read 0, byteval0
        read 1, byteval1
        read 2, byteval2
        read 3, byteval3
        lcdout $fe,1,"LongVal:", dec longval
        lcdout $fe,$94,"10:",bin8 byteval1," ",bin8 byteval0
        lcdout $fe,$D4,"32:",bin8 byteval3," ",bin8 byteval2
        goto test
  1. linear data memory & large data arrays
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 28th June 2011, 00:21
  2. Replies: 11
    Last Post: - 17th August 2010, 17:45
  3. LONG Data type
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 05:06
  4. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  5. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 19:38
