Hi there,
You can try to amplify (buffer) the signal from the port pins through a single npn transistor and connect the the collectors of both to the buzzer if you are using thge sound function. If you are using a self oscillatory piezo buzzer then just and the ports using two diodes (4007 or such) and should get satisfactory result.
Sougata
