Pic16f18857 clock setup
Results 1 to 10 of 10
    Jan 2010
    Default Pic16f18857 clock setup
    I'm hitting my head against the wall now. I can't seem to figure out this new chip. I just want to get it up and running with the internal oscillator at 32Mhz. When I blink an led with a 1 sec interval it's way to fast. If anyone can give me a walk through that would be great.
    Dec 2010
    Default Re: Pic16f18857 clock setup
    If it is blinking too fast, that would point to your clock speed being too high which is extremely unlikely. Are you absolutely sure your code is correct? Perhaps you should post your blink code.
    Yes, it's not very likely that the PIC is running faster than 32MHz.
    There's two parts to it. Get the PIC to actually run at the desired frequency and inform the compiler what that speed is so it can get its timing calculations correct. If you don't tell the compiler that you're running the PIC at 32MHz it defaults to 4MHz and your PAUSE 1000 will in effect become a PAUSE 125.
    Jan 2010
    I was following the data sheet and it must be set for 32Mhz because when I used a pause of 1000 and hooked up the oscilloscope to it I was getting 125ms. I used the define 32 in PBP but it doesn't seem to work. I've never used a chip like this, the oscon register is different. I'll try again tomorrow.
    define OSC 32
    OSC is case sensitive, the rest is not.
    Jan 2010
    I've tried so many thing now with no luck. Here is the config setup in 16f18857.inc file. A pause 1000 led on & off program is giving me 125ms on the scope.
    __config _CONFIG1, _FEXTOSC_HS & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
    It's my understanding that on reset the internal clock will be running at 32Mhz with these fuses set. I've tried simply setting Define OSC 32, and adding OSCFRQ = %00000110.
    There are three OSCCON registers and OSCEN register. I'm off in the weeds and don't know which way to go at this point.
    I did notice that when I program the chip with meProg that the configuration HFINTOSC WITH 2X PLL was set instead of HFINTOSC like the fuse is set for. I changed that and my blink program goes from 125ms to 2sec. For what it's worth. Any help would be appreciated thanks.
  1. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 17:44
  2. Use Button For setup
    By tump in forum mel PIC BASIC Pro
    Last Post: - 21st November 2007, 19:43
  3. LCD setup
    By ruijc in forum General
    Last Post: - 19th November 2007, 09:04
  4. pic12f683 setup
    By erice1984 in forum mel PIC BASIC Pro
    Last Post: - 4th July 2007, 11:48
  5. How to setup Bootloader
    Last Post: - 8th January 2006, 19:52
