And you're using a BYTE sized variable to do it.Code:TRISA=255 ' Set all PORTA pins to Input dip var byte Start: dip=PORTA select case dip case 0 ' ' Code for PORTA=0 ' case 1 ' ' Code for PORTA=1 ' case 2 ' ' Code for PORTA=2 ' end select goto start
