Set bits of Word problem
Results 1 to 5 of 5
    Cool Rtfm ...
    Hi, Pdegior
    I saw something in the manual ....$ 4.17.14 ...
    Have a look to it ...
    Default Freebie!!!
    TRISA=255  ' Set all PORTA pins to Input
    dip var byte
    Start:
        dip=PORTA
        select case dip
            case 0
                ' Code for PORTA=0
            case 1
                ' Code for PORTA=1
            case 2
                ' Code for PORTA=2
            end select
        goto start
    And you're using a BYTE sized variable to do it.
    Hi Pdegior. I tested this program with only part of PORTA and it works. Hope this helps.
    'CODE COMPILED FOR 16F818
    OSCCON = $60 'set int osc to 4mhz
    adcon1 = 7 ' set inputs to digital
    TRISA = %11111111 'ALL PORTA INPUTS
    TRISB = %00000000 'ALL PORTB OUTPUTS
    PORTB = 0 'ALL OUTPUTS LOW
    @ DEVICE MCLR_ON, INTRC_OSC, WDT_ON, LVP_OFF, BOD_ON, PWRT_ON, PROTECT_ON
    DIP VAR BYTE
    START:
    PORTB = 0 'off all leds
    LET DIP = 0 'clear the variable DIP
    LET DIP.BIT0 = 0
    IF PORTA.0 = 1 Then LET DIP.BIT0 = 1 'dip bits are 0 unless PORTA bit is high
    LET DIP.BIT1 = 0
    IF PORTA.1 = 1 Then LET DIP.BIT1 = 1
    LET DIP.BIT2 = 0
    IF PORTA.2 = 1 Then LET DIP.BIT2 = 1
    LET DIP.BIT3 = 0
    IF PORTA.3 = 1 Then LET DIP.BIT3 = 1
    IF DIP = 0 Then High PORTB.0 'light corresponding LED
    IF DIP = 1 Then High PORTB.1
    IF DIP = 2 Then High PORTB.2
    IF DIP = 3 Then High PORTB.3
    Pause 1000 'wait a second
    PORTB = 0 'off led
    GoTo START 'do it again
    Jul 2005
    that seems to have done it. Still not too sure why the way I had it doesn't work but oh well.
    Last Post: - 14th June 2016, 08:55
  2. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 01:40
  3. Interruptus Frustratus
    Last Post: - 17th April 2009, 21:36
  4. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  5. How to isolate 10 bits from word variable?
    By rcbandwidth123 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:18
