Communications Protocol Choices
Results 1 to 9 of 9
    Default Re: Communications Protocol Choices
    i2c would be my last choice , pbp has no slave implementation, no hardware implementation
    spi is easy and fast uses hardware but not brilliant at several metres in noise
    but then again pbp has no built in functionality for spi modules
    rs232/tty ,rs485 are good at distance and noise and use the hardware modules , a little slow
    you make no mention of transfer speeds , frequency or data size
    For good noise immunity I would suggest RS-485 for any distance. I use a protocol which is loosely based on Modbus RTU.
    EN82fn
    OK
    As for transfer speeds, I intend to use a Rotation variable in the Master that polls one peripheral MCU each pass of the Main loop. Transfer size is 2 bytes; first byte is what the data is (Temp) while the second is the value of that variable (71).
    Here is something I found quite a while ago. Use it as a starting point...
    EN82fn
    OK
    Thanks Dave, I downloaded it and will give it a thorough looking over.
  1. LCD port bit choices
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd September 2006, 11:22
  2. RF communications
    By Ron Marcus in forum Forum Requests
    Last Post: - 3rd November 2005, 00:28
  3. OBD II Protocol
    By L_Gaminde in forum mel PIC BASIC Pro
    Last Post: - 30th July 2005, 07:12
  4. Map27 Protocol
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 16th February 2005, 03:53
  5. Sony Protocol help
    By zazery in forum mel PIC BASIC Pro
    Last Post: - 30th April 2004, 05:00
