How can I use for next like PORTB.MYVARIABLE ???
Results 1 to 11 of 11
    obaskirt's Avatar
    obaskirt Guest
    Red face
    Quote Originally Posted by mister_e
    for LED=0 to 7
         HIGH LED
        PAUSE 500
        LOW LED
        PAUSE 500
        NEXT
    My problem is; I can not define PORTB.LED??? and in your example which port did you make high or low? For example, I connected 8 leds to PIC 16F84's PortB. How can you turn on then turn of these leds by using for next loop. Also you can do this by left and right shift operator but I am curious about how can this problem accomplish by using for-next loop. Thankss..
    MaurI's Avatar
    MaurI Guest
    i var byte
    x var byte
    TRISB=0
    i=0
    begin
    For i=0 to 7
    Lookup i,[1,2,4,8,16,32,64,128],x
    PORTB=x
    Pause 200
    next i
    i=0
    goto begin
    Well in this little sample there is For next so check it out!
    And don't use those High and Low if it is possible better use =0, =1 - it will save your code space
    Quote Originally Posted by obaskirt
    low = 0 does the same thing as low portb.0. You can address portb 0-7 and portc 8-15 like this. I'm not sure if you can access other ports in this fashion or not though.
