Switching PSU problem
Results 1 to 17 of 17
    Jun 2007
    Mansfield, UK
    Default Re: Switching PSU problem
    I know it might not be clear from the images but every single screw hole in both PCBs (and the metal connector) are all definitely connected to PCB ground. The ground plane is on the bottom of the PCB and top is 3.3V which is why the screws holes aren't connected to anything on the top of the PCB. They are plated through to the bottom though.
    The PSU secondary isn't grounded internally (though I will try that as you suggested). It is still grounded though because it connects to the PCB ground which has the green wire connected to it. It's a longer path but it's still connected to earth.
    Is removing the green wire from the PCBs just to see what happens or are you suggesting this as a permanent fix? If I replace that capacitor looking thing with a short then I guess everything would still be grounded but I'd feel better knowing I have an actual earth wire attached in case one of the connectors comes loose.
    relying on the psu cover to be screwed on for earthing continuity is not a good look.
    Is this referencing the blue capacitor like thing that connects to the case rather than directly to the earth terminal?
    I don't think that would be so bad as the case is always supposed to be on and I have separate grounding wires for the PCB grounds.
    I could add a wire between the earth terminal and the negative secondary and also an earth wire directly to the case just to be sure.
    I'll test everything you've suggested as soon as possible and report back. I know someone who has a better multimeter so I will see if I can try with that.
    Sep 2009
    If - is bottom, then metal connector should go at bottom.
    Screw doesn't make good contact. Also on vertical board with LCD, I don't see exposed copper or tin around metal connector.
    Jun 2007
    Mansfield, UK
    I can move the connector to the bottom. It shouldn't be causing this problem though. The PCB has about 6mm of tin around the hole on both sides of the board and the hole is plated through.
    The LCD board is exactly the same (6mm tinned both sides and plated through). On that board the ground plane is on the same side as the green wire.
    Sep 2009
    Can you measure resistance between socket and GND on board and post picture while measuring.
    I really can't understand that there is static build up, and all symptoms associated with it, and such low impedance path to ground.
    Can you test your main's ground? I don't know from where you are, but try to measure voltage between neutral and GND.
  1. LED Dimmer - What should be used for Switching?
    By FromTheCockpit in forum Schematics
    Last Post: - 4th November 2012, 01:31
  2. Replies: 1
    Last Post: - 12th May 2012, 13:37
  3. Zero cross detect - switching audio
    By HankMcSpank in forum General
    Last Post: - 1st November 2011, 19:59
  4. Oscillator Switching
    Last Post: - 25th July 2010, 03:28
  5. Auto SCART switching
    Last Post: - 5th August 2008, 01:12
