Powering 16F628 From Stable 12vDC
Results 1 to 9 of 9
    Oct 2003
    holland
    When you take 300 mA and the voltake over the LM317 is 24 - 8 = 16 volt. The power into the LM317 is 16 x 0,3 = 4.8 watt.
    So you have to cool that power down. The power in the LM7805 is less 0,3 x 3 = 0.9 watt. For this power you need also cooling.
    LM2578 is may be usable
    Feb 2005
    GREECE
    Hi Acetronics,
    Could you please suggest me a common switching supply.
    Do you mean dc-dc step down converter?
    Wink
    Quote Originally Posted by ngeronikolos
    Hi Acetronics,
    That's the kind of question I CAN'T answer : you live in a different country with a widely different market !!!
    > Do you mean dc-dc step down converter ?
    Yes, National has lots of down converters, in the LM 25xx series you mentionned.
    And the Datasheet is really crystal clear for components around ...
    do not forget a small ( LoL ) heatsink will also be necessary ...
    Jul 2005
    The Netherlands
    Default LT1933 step-down
    I use for a lot of applications the LT1933. (Linear Technology)
    A very small device, external a few resistor, diode and 1 coil of 22uH.
    See the internet for specs.
    We currently use th LM2574-5.0 just for this reason. Our 5V line require around 200mA-300mA which when run through a linear regulator I could probably heat my house since our source voltage is 24VAC which comes up to around 30-35VDC. The regulator works quite nice and is pretty cheap. I've run it up to about 350mA-400mA and it does get warm to the touch but not hot by any means.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Good (stable) voltage regulator?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 18th December 2005, 20:39
  3. Interface DB-25 Female Connector to PIC 16F628
    By JoeCJK in forum Schematics
    Last Post: - 20th April 2005, 06:06
  4. SERIN2 not working with 16F628
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 21:37
  5. 16F628 on-chip eeprom problem
    By atomski in forum mel PIC BASIC Pro
    Last Post: - 4th March 2004, 08:43
