AD9833 Example
Results 1 to 6 of 6
Thread: AD9833 Example
    Default AD9833 Example
    I have been working on a program to run an AD9833 module by inputting the frequency in kHz and Hz in decimal. It is a work in progress and will end up being driven by a rotary encoder and/or a keypad. I claim no credit for the arithmetic part of the program, this uses a combination of Darrel Taylors' N Bit Math and a modified version of a program by, I think, Henrik Olsson. Haven't had any problems so far controlling an SPI device using SHIFTOUT.
    PRECISION CON 5 SYSTEM
    INCLUDE "N-bit_Math.pbp" ' Include the math routines.
    include "modedefs.bas"
    ADCON0=7 'MESSES UP SERIAL COMMS IF OMITTED
    ADCON1=7
    ' Create some variables for the math routines to use.
    MathVar1 VAR BYTE[PRECISION] ' Used by N-Bit math routines
    MathVar2 VAR BYTE[PRECISION] ' Used by N-Bit math routines
    MathVar3 VAR BYTE[PRECISION] ' Used by N-Bit math routines
    Compensator VAR WORD
    LSB VAR WORD'LEAST SIGNIFICANT BYTE OF TUNING WORD
    MSB VAR WORD'MOST SIGNIFICANT BYTE OF TUNING WORD
    LSBL VAR BYTE:LSBH VAR BYTE'SPLIT LSB WORD INTO 2 BYTES
    MSBL VAR BYTE:MSBH VAR BYTE'SPLIT MSB WORD INTO 2 BYTES
    DATAPIN3 var PORTA.0
    CLOCKPIN3 var PORTA.1
    FSYNC var PORTA.2
    kHz VAR WORD
    Hz VAR WORD
    MAIN:
    KHZ=1
    HZ=500
    gosub CalculateTuningValue
    LSB=((MATHVAR1[0]+(MATHVAR1[1]&%00111111)<<8))+$4000'SEPARATE LOW 14 BITS AND SET BIT 15 TO 1
    MSB=((MATHVAR1[1]>>6)+(MATHVAR1[2]<<2)+(MATHVAR1[3]<<10))+$4000'SEPARATE HIGH 14 BITS AND SET BIT 15 TO 1
    LSBL=LSB&$FF:LSBH=LSB>>8'SEPARATE HIGH AND LOW BYTES
    MSBL=MSB&$FF:MSBH=MSB>>8'SEPARATE HIGH AND LOW BYTES
    HIGH FSYNC:PAUSE 2
    HIGH CLOCKPIN3:PAUSE 2
    LOW FSYNC
    SHIFTOUT datapin3,clockpin3,5,[$21,$00,LSBH,LSBL,MSBH,MSBL,$C0,$00,$20,$00]
    HIGH FSYNC
    SEROUT2 PORTB.0,84,[HEX2 LSBH,HEX2 LSBL,HEX2 MSBH,HEX2 MSBL,10,13]
    goto MAIN
    CalculateTuningValue:
    ' Multiply the kHz variable by 1000 to get from kHz to Hz
    @ MOVE?WP _kHz, _MathVar1 ; Move WORD to P_VAR
    @ MOVE?CP 1000, _MathVar2 ; Move 1k to P_VAR
    @ MATH_MUL _MathVar1, _MathVar2, _MathVar3 ; Multiply, store result in MathVar3
    ' Add the Hz variable to the previously calculated result
    @ MOVE?WP _Hz, _MathVar2 ; Move WORD to MathVar2
    @ MATH_ADD _MathVar3, _MathVar2, _MathVar1 ; Add MathVar3 to MathVar2, result in MathVar1
    ' Multiply the previous result by 87961.
    @ MOVE?CP 87961, _MathVar2 ; Load constant to MathVar2
    @ MATH_MUL _MathVar1, _MathVar2, _MathVar3 ; Multimply, result in MathVar3
    ' Add 4096 to the current result. This is done to perform rounding of the value
    ' to the closest integer when later dividing by 8192 instead of simply truncating
    ' the value as would be the case otherwise.
    @ MOVE?CP 4096, _MathVar2 ; Load constant to MathVar2
    @ MATH_ADD _MathVar3, _MathVar2, _MathVar1 ; Add to MathVar3, result in MathVar1
    ' Divide the previous result by 8192 to end up with the final tuning value.
    @ MOVE?CP 8192, _MathVar2 ; Load MathVar2 with the value 64
    @ MATH_DIV _MathVar1, _MathVar2, _MathVar3 ; Divide, result now in MathVar3
    ' By subtracting a proportion of the value of the kHz variable to the calculated tuning value
    ' we can get a little closer to the exact value.
    Compensator = kHz ** 550 '550/65536
    @ MOVE?WP _Compensator, _MathVar2 ; Move value to P_Var
    @ MATH_SUB _MathVar3, _MathVar2, _MathVar1 ; Add it to previous result.
    Default Re: AD9833 Example
    Thanks for the code. Planning to use this IC for a frequency generator. What I wanted to ask, I don't need such great precision nor waveform control. All I need is to generate square wave, resolution 1 hz, frequency from 50hz to 10Khz. Can above code be simplified for that task?
    For those frequency's, Why not just use a PIC with an NCO module? No need for other hardware...
    EN82fn
    need at least 4 outputs, with independently adjustable frequencies.
    How are you going to do that with 1 AD9833?
    EN82fn
    I'm going to use 4 of them ready to use board costs $1.5 in china
  1. Help for controll DDS AD9833 Chip !!!!! :-((
    By martin109 in forum mel PIC BASIC Pro
    Last Post: - 25th May 2005, 13:54
  2. Help for controll DDS AD9833 Chip !!!!! :-((
    Last Post: - 25th May 2005, 13:52
