Need help with LAT instruction
Results 1 to 11 of 11
    Default Re: Need help with LAT instruction
    Alberto, read about "read modify write" and you'll understand the purpose of LAT. If you write to PORTx and read from LATx you should be squeaky.
    George
    OK
    Quote Originally Posted by towlerg View Post
    That's his way of saying don't do it. Read from PORT and write to LAT is the correct message conveyed.
    Mike, I did a little research and came to the conclusion that you should both read and write the LAT register.
    My logic is a follows, as you correctly say you must write to LAT (to set the latches and thus remember the correct state of the gpio ) but if you read from the PORT you're still left with the RMW problem. But is you read from LAT that goes away.
    Alberto, sorry for the confusion.
    George
  1. Replies: 125
    Last Post: - 24th June 2018, 14:44
  2. Instruction cycle measurement
    Last Post: - 6th August 2012, 07:50
  3. LAT replaces PORT command?
    By markscotford in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2011, 16:37
  4. Instruction times
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 5th June 2009, 09:16
  5. What does this MCLR instruction mean?
    By bartman in forum General
    Last Post: - 30th November 2004, 00:32
