Compiling USBMouse.bas
Results 1 to 3 of 3
    Jul 2005
    Selangor, Malaysia
    Red face Compiling USBMouse.bas
    Hi all,
    I'm new here and seeking for help. I try to compile the USBMouse.bas but come out with many errors :
    Warning[230] c:\pl\pbp\18f4455.inc 24: _config has been deprecated for PIC18 devices. Use directive config.
    Error[105] c:\pl\pbp\pbpusb18.lib 11:cannot open file (include file "\pbp\pbppic18.lib" not found)
    and etc
    From the usb.txt in the USB18 folder, it is saying that some files need to copy into the project source subdirectory. Please highlight me with this: the files need to copy, and what is the mean by "project source subdirectory".
    Please assist as soon as possible.
    kblim
    iblaster's Avatar
    iblaster Guest
    PBP seems to like it is the compiler is in c:\pbp instead of c:\{some dir}\pbp. I had this problem and then renamed the compiler directory to c:\pbp and it was fine. Or you could creat a c:\pbp directory and then copy the pbppic18.lib file to that dir. Just ignore the warning message. It is from the compiler saying that the config syntax has changed. Also make sure that you copy the 18Fxxxx.bas files from the usb18 sub directory to the \pbp directory, as these are different .bas files for using the USB features. Be sure to rename the original 18Fxxxx.bas files that are in the \pbp directory to something else.
    Jul 2005
    Selangor, Malaysia
    Thanks! I will try it.
  1. Vista 64 bit OS Compiling
    By skorp in forum mel PIC BASIC
    Last Post: - 28th July 2009, 21:18
  2. Compiling Error with 18F452
    By michel in forum mel PIC BASIC Pro
    Last Post: - 1st July 2008, 06:10
  3. Replies: 1
    Last Post: - 21st February 2008, 16:36
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. Compiling problems
    Last Post: - 7th June 2005, 01:58
