Binary to BCD conversion
Results 1 to 9 of 9
    Default Re: Binary to BCD conversion
    Well John, Here is the way I would do it. Assuming all 4, 8 bit counters are connected in series to get 32 bits:
    BIGNUM VAR LONG
    VALUE VAR BYTE
    JUNK VAR BYTE
    CHARPOS VAR BYTE
    DIGVALUE VAR BYTE
    MAIN:
    'THIS ASSUMES ALL 4, 8 BIT COUNTERS ARE IN SERIES ON SAME DATA AND CLOCK LINE
    'ADJUST DATA AND CLOCK LINE TO YOUR HARDWARE CONFIGURATION
    SHIFTIN REGDATAPIN,REGCLKPIN,MSBFIRST,[BIGNUM.BYTE3,BIGNUM.BYTE2,BIGNUM.BYTE1,BIGNUM.BYTE 0]
    '32 BIT VALUE IS CLOCKED IN TO LONG VARIABLE
    JUNK = 7 'SET DIGIT POINTER FOR 8 DIGITS TOTAL
    WHILE JUNK < 255
    VALUE = BIGNUM DIG(JUNK) 'VALUE OF DIGIT
    CHARPOS = JUNK + 1 'CALCULATED CHARACTER POSITION
    low load
    shiftout datapin,clockpin,MSBFIRST,[CHARPOS, VALUE] 'DATA SHIFTED TO DISPLAY
    high load
    JUNK = JUNK - 1 'NEXT DIGIT FROM MSBYTE TO LSBYTE
    WEND
    I hope this bit of code will help you.
    EN82fn
    Dave,
    Thank you for sharing this, your method does seem a lot simpler. I don't have LONGS available but imagine this could be worked around. I would be interested in having a go with something based on your method and see if there is much difference in the size of the compiled program.
    George,
    Thanks for your reply. I am a little confused though, does this convert to ASCII rather than BCD?
    John
    I think I misunderstood the question, I thought BCD was a way of expressing a binary value as ASCII characters. So for example a byte would become two ASCII chars, a word 4 ASCII chars etc.
    George
    John, If you limit the accumulated value to say 5 digits as in a word (65535 max) then you can use it without LONG's. I use this method to display MPH with 3 decimal places on a terminal thru a serial port by adding:
    TX_BYTES(TX_OUTPUT) = $30 + VALUE DIG JUNK 'Turn decimal value into ASCII
    EN82fn
    Dave,
    Interesting approach, seems like I got too bogged down in shifting and adding multiple times rather than using the more obvious arithmetic capabilities of PICBASIC.
    George,
    Thanks for the hint on conversion to ASCII, I'm sure it will come in useful at some stage.
    For info, BCD represents the decimal digits 0-9 using a nibble of data. With BCD only the states 0-9 are valid. 0xA to 0xF are forbidden. Its used for seven segment displays, real time clock modules, etc.
  1. Trouble Reading Binary or BCD from a GPS
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 7th August 2011, 18:27
  2. Nice tutorial on BCD to Binary
    Last Post: - 9th December 2010, 18:21
  3. PIC16F628 - Convert Binary to BCD?
    By steng in forum mel PIC BASIC Pro
    Last Post: - 20th March 2009, 08:17
  4. BCD conversion
    Last Post: - 17th October 2005, 19:24
  5. HEX to BCD conversion
    Last Post: - 2nd February 2005, 14:39
