Sorry, but another interrupt problem
Results 1 to 15 of 15
    Tom, Trying using the insert code option. Make it much easier to read. The command is:
    (code)
    blah
    blah
    blah
    (/code)
    The the () with [].
    Australia
    Hi Tom,
    You can try goto instead of gosub and change 'pause n' into
    for i = 1 to n
    pause 1
    next i
    everywhere except inside of the interrupt subroutinue. Of course, if statements within gosub takes several mill-seconds, then leave it is.
    I use the above method in my project and it works. You may try it and let me know the result.
    Once again, PBP is very latency interrupt implementation because it must finish the current statement execution before jumping into the interrupt subroutinue. So make sure the jobs within each statement take short time as possible as you can.
    Yuantu Huang
    tbirchall's Avatar
    tbirchall Guest
    Default It's fixed!
    Ahhhhh! I can't belive it. I'm embarrassed to say it was a leftover line of code from when I was trying to get it working originally. In the displayTime routine, I had a call to LOW 0. This would have changed the pin to be an output and therefore no longer would be triggered by the interrupt button. Doh!
    Thank you everyone for all the help. You rock!
    -Tom
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
