Whilst I prefer to use @SLEEP rather than NAP, I did once experience an anomaly (about three years back - probably PBP v2.42) whereby a couple of instructions following the @SLEEP were not executed properly. I cured the problem (without investigating further due to lack of time) by inserting half a dozen @NOP statements before I resumed with any proper code... the reasoning behind that was if it was going to misbehave and skip a couple instructions then the NOP's would absorb the anomaly and contine as it was intended. Anyhow, it worked for me, might be worth trying to see if it does it for you.
