Sorry, but another interrupt problem
Results 1 to 15 of 15
    tbirchall's Avatar
    tbirchall Guest
    Default Sorry, but another interrupt problem
    I'm a newbie just can't seem to get this working. I've checked the other posts but I don't see what I'm doing wrong. I'm trying to receive an interrupt from push button connected to portb/0. I am using a PIC16F84A and here is the code:
    Include "modedefs.bas"
    CLEAR
    LOW 7
    TRISB.0 = 1
    INTCON = %10010000
    ON INTERRUPT GOTO handleInterrupt
    PAUSE 1
    GOTO main
    DISABLE
    handleInterrupt:
    HIGH 7 ' turn on LED so I know it worked
    PAUSE 1000
    LOW 7
    INTCON.1 = 0
    RESUME
    ENABLE
    If the problem isn't in the code, it might also be how I've got the push button hooked up. (Like I said, I'm a newbie.) I've tried several things, but right now I have one lead on the push button connected to 5v+ and the other lead connected to portb/0. I've tested the LED and switch separately, and they both work and the code compiles as well.
    Any help is GREATLY appreciated.
    what else on the PORTB.0 pin??? any pull-down resistor???
    Should have one, if not it could act weird.
    Another altenative is to use the internal PULL-UP and connect your push-buuton between RB0 and GND
    OPTION_REG = 0 ' enable internal pull-up and interrupt on RB0 falling edge
    Australia
    You should initialise the INTEDG bit of OPTION_REG. If you would like to make falling edge interrupt, just add OPTION_REG.6 = 0 after INTCON = %10010000
    Yuantu Huang
    This is why i suggest my previous. BTW in the first post PB was connected to VCC and OPTION_REG.6 is set to 1 at start-up wich is already rising edge.
    tbirchall's Avatar
    tbirchall Guest
    Default Thank you
    Thank you very much. That did the trick. It is really great to have such knowledgable people to turn to. Thanks for taking the time.
    -Tom
    tbirchall's Avatar
    tbirchall Guest
    Default Another question
    OK, I hate to be a pest but... I got the sample code working, but when I apply it to my real code, it only works once. Basically, what I'm trying to achieve is to have the program wake on interrupt, do something, then go back to napping. This is to save power since it is a battery powered project. So, my loop looks like this:
    loop:
    NAP 0
    PAUSE 1
    GOSUB blah
    GOTO loop
    The idea is that all the interrupt does is to clear the flag, then the code will resume at the next line of code - in this case, the PAUSE statement. If I have a simple HIGH/LOW FOR/NEXT loop that lights an LED, it works perfectly over and over again. If I have my gosub (like above), then it works once and that's it - the interrupt never gets called again. Can someone tell me conceptually what is going on? My gosub has one other gosub nested in it, so I don't think it is too deep. Oh, and blah does have a return and my interrupt routine is wrapped in DISABLE and ENABLE calls. Thank you!
    -Tom
    Whilst I prefer to use @SLEEP rather than NAP, I did once experience an anomaly (about three years back - probably PBP v2.42) whereby a couple of instructions following the @SLEEP were not executed properly. I cured the problem (without investigating further due to lack of time) by inserting half a dozen @NOP statements before I resumed with any proper code... the reasoning behind that was if it was going to misbehave and skip a couple instructions then the NOP's would absorb the anomaly and contine as it was intended. Anyhow, it worked for me, might be worth trying to see if it does it for you.
    Talking
    Out of topic by why people say half dozen?
    SIX
    3 letters, same mean. sorry. couldn't resist
    Australia
    Hi Tom,
    The problem might be caused by gosub, which might take too much time, because PBP uses very latency interrupt implementation, and it never jumps into interrupt subroutinue within gosub. Please read Section 9.2 "Interrupt in Basic" in PBP manual. If you use goto instead of gosub, the problem may be fixed. That is,
    change
    gosub AAA
    AAA:
    into
    goto BBB
    CCC:
    BBB:
    goto CCC
    If the above does not work, you have no choice but using assembly interrupt.
    Yuantu Huang
    FALSE, interrupt will jump from anywhere in your code. gosub or goto make absolutely no difference. Latency will be caused by some function BUTTON,SOUND,PAUSE to name only those.
    Personnally, for my design, i've never found a REAL BIG difference between regular and assembly interrupt once the code is properly written.
    BTW, post a whole code, not only a snip of it, we will help.
    Ooh, come on now, don't be a Scrutz!!
    Quote Originally Posted by mister_e
    SIX
    Six means exactly six.
    But "half a dozen" displays the authors/speakers feeling about the quantity (which I guess in Melanies case was too many instructions).
    tbirchall's Avatar
    tbirchall Guest
    Default code this time
    OK, I tried adding the 12/2 @NOPs, but it reacted the same. Here is some code:
    loop:
    nap 0
    pause 15
    ' this works repeatedly just fine
    ' for index = 0 to 5
    ' high 7
    ' pause 250
    ' low 7
    ' pause 250
    ' next
    @NOP
    @NOP
    @NOP
    @NOP
    @NOP
    @NOP
    ' this works the first button press but never again
    gosub callTime
    GOTO loop
    ' my interrupt routine
    disable
    handleInterrupt:
    high 7
    pause 250
    low 7
    INTCON.1 = 0
    resume
    enable
    callTime:
    ' clear the display
    gosub clearDisplay
    ' show time
    gosub displayTime
    pause 2000
    ' clear the display
    gosub clearDisplay
    clearDisplay:
    for index = 1 to 2
    shiftout LEDData, LEDCLK, MSBFIRST, [index]
    shiftout LEDData, LEDCLK, MSBFIRST, [-1]
    pulsout LEDLoad, 5
    next
    for index = 3 to 4
    shiftout LEDData, LEDCLK, MSBFIRST, [%00000000]
    pulsout LEDLoad, 5
    next
    displayTime:
    ' read time from DS1302
    GOSUB ReadRTCBurst
    ' get hours
    I = Hours
    if (I > 12) then I = (I - 12)
    if (I < 8) then
    high 0
    I = (I - 1)
    I = (%01000000 >> I)
    shiftout LEDData, LEDCLK, MSBFIRST, [3]
    low 0
    I = (I - 8)
    shiftout LEDData, LEDCLK, MSBFIRST, [4]
    shiftout LEDData, LEDCLK, MSBFIRST, [I]
    pulsout LEDLoad, 5
    ' get tens of minutes
    I = (Minutes >> 4)
    shiftout LEDData, LEDCLK, MSBFIRST, [1]
    pulsout LEDLoad, 5
    ' get minutes
    I = (Minutes & $0F)
    shiftout LEDData, LEDCLK, MSBFIRST, [2]
    pulsout LEDLoad, 5
    So, did anyone read this far? Sorry for the length. Basically, I'm reading time from a DS1302 and then pumping it out to a MAX7219 LED driver. Part of the time is in LED's and part is in segment displays. The time stuff and display all seems to work fine - if I'm not calling it from after an interrupt.
    Thank you again!
    -Tom
    Tom, Trying using the insert code option. Make it much easier to read. The command is:
    (code)
    blah
    blah
    blah
    (/code)
    The the () with [].
    Australia
    Hi Tom,
    You can try goto instead of gosub and change 'pause n' into
    for i = 1 to n
    pause 1
    next i
    everywhere except inside of the interrupt subroutinue. Of course, if statements within gosub takes several mill-seconds, then leave it is.
    I use the above method in my project and it works. You may try it and let me know the result.
    Once again, PBP is very latency interrupt implementation because it must finish the current statement execution before jumping into the interrupt subroutinue. So make sure the jobs within each statement take short time as possible as you can.
    Yuantu Huang
    tbirchall's Avatar
    tbirchall Guest
    Default It's fixed!
    Ahhhhh! I can't belive it. I'm embarrassed to say it was a leftover line of code from when I was trying to get it working originally. In the displayTime routine, I had a call to LOW 0. This would have changed the pin to be an output and therefore no longer would be triggered by the interrupt button. Doh!
    Thank you everyone for all the help. You rock!
    -Tom
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 02:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
