Simple subtraction
Results 1 to 9 of 9
    Aug 2003
    Default Re: Simple subtraction
    You can use a word somewhat like a float, but essentially, I believe you can compare those two types.
    Even if they didn’t directly compare, you could compare the byte to the lower word byte, and if the upper word byte is zero,
    the first compare with he lower byte is valid. otherwise if the upper word byte is not zero, the word is higher.
    In PBP all variable types stores integer values only so only the size of the number they can hold changes. The resolution is always the same.
    I see no, and don't know of any, issues with comparing a BYTE to WORD or the other way around but again remember that BYTES and WORDS are always unsigned integers so a variable containing 253 will be smaller than a BYTE (or WORD) variable containin the result of 100-101.
  1. Replies: 4
    Last Post: - 2nd November 2012, 09:47
  2. This should be simple?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 29th September 2008, 21:20
  3. Addition and subtraction
    Last Post: - 25th January 2008, 14:24
  4. This is probably quite simple
    By Russ Kincaid in forum mel PIC BASIC
    Last Post: - 9th August 2006, 14:30
  5. Simple If.. Then help:
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 17th June 2005, 20:05
