Increase Current on Pic's Pin.
Results 1 to 8 of 8
    Unhappy Increase Current on Pic's Pin.
    Good day Picers
    A slightly off topic question?
    I've got a Component that requires about 60mA from my PIC's PIN.
    I'm trying to figure out how to use a PNP Transistor as a switch to get a greater current from my circuit?
    I know that if you use different resistors it will give you different current from the Emitter to the collector.
    Is there a formula to determine what size resistor to use to get a specific amount of current through the transistor?
    Rb = (VCC - Vbe) / (Ic/HFE) = (5-.6) / (.06 / 100 ) = 7.1666 K = 6.8K
    safer to use lower value 680 ohm is a really safe one.
    Question
    Thank you Steve!
    VCC = Input voltage
    What is Vbe, Ic, HFE?
    Ic = Collector current
    Vbe = voltage between Base and Emitter
    HFE = Transistor gain, you'll find that one in the datasheet
    Thank you!!
    Aug 2005
    Michigan, USA
    You didn't mention if you need to sink or source current to the device? Either way, have you considered using an N-channel (sink) or P-channel (source) MOSFET instead of a bipolar transistor?
    Regards, Mike
    Lightbulb
    Hi Mike
    I'm using a PNP transistor to source current.
    Didn't you mean use a 6.8k?
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Pin max current - short duration?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 13:53
  3. Microcontroller with 2 way paging application problem
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. Tx and Rx of Single Pin PIC's
    By Dwayne in forum Code Examples
    Last Post: - 26th May 2004, 15:55
