Onewire.pbp sample program -- high readings
Results 1 to 5 of 5
    Default Onewire.pbp sample program -- high readings
    This program --
    http://melabs.com/samples/PBP-mixed/onewire.htm
    works fine but at room temperature I'm getting --
    178 C
    350 F
    I am using a probe with a DS18B20 sensor, perhaps that's it but I can't imagine why, the temperature storage is word and I read where the DS18 B 20 has higher resolution?
    Anyway, can anyone see why I'm getting these high readings?
    I simply did a copy and paste with the code -- didn't change a thing. -- Thanks.
    Default Re: Onewire.pbp sample program -- high readings
    a ds18b20 is not a ds18s20 , the code you linked is for a ds18s20. check the data sheets
    a ds18b20 does not have or use count_remain, count_per_c at all. there are plenty of examples for either device in the forum but
    some do not explicitly state which device they match. caveat emptor
    check these scratch pad definitions
    Oct 2009
    This works for me using DS18B20
    DQ                 VAR PORTA.5          'One-wire data pin for Ds18B20
    GIE             VAR INTCON.7
    temperature     VAR     WORD            ' Temperature storage
    'Get and display the temperature
    GIE = 0
    owin DQ, 1, [],NoDevice                 ' pole 1 wire bus - if no responce then device not pressent
    OWOUT DQ, 1, [$CC, $44]                 ' Start temperature conversion
    OWOUT DQ, 1, [$CC, $BE]                 ' Read the temperature
    OWIN DQ, 0, [temperature.LOWBYTE, temperature.HIGHBYTE]
    GIE = 1                                 ' turn interupts back on
    temperature = temperature */ 1600
    lcdout $FE,$D4+0,"TEMP ",dec(temperature / 100),$DF,"C"
    NoDevice:
    lcdout $FE,$D4+0,"TEMP N/C   "
    GIE = 1
    Ok thanks much -- didn't notice the "S".
    I looked at this --
    https://www.maximintegrated.com/jp/a...ex.mvp/id/4377
    and I see the difference in the memory map, but can the example --
    be easily adapted to work with the 18B20 maybe? Just want to get this going.
    I just did a search for DS18S20 probe and it also shows it as DS18B20. And yet, you're saying they are not the same animal. ? These listings seem to think they're the same. (!) wrong ?
    https://www.ebay.com/sch/i.html?_fro...probe&_sacat=0
    I'll try your code Scampy -- thanks. Would like to be able to modify the melab sample though as I have it inside some other code and a complex breadboard already setup.
  1. LCD -- melabs sample program
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 19th June 2017, 14:42
  2. Lcd 16x2 circuit and sample program...
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2012, 12:21
  3. unstable ADCIN readings when using DT ELAPSED.PBP
    By peter_wiersig in forum General
    Last Post: - 27th February 2010, 20:16
  4. DS2438 onewire code sample
    By Captain Stern in forum mel PIC BASIC Pro
    Last Post: - 21st January 2007, 03:47
  5. DS1307 sample Program
    By Mark in forum mel PIC BASIC Pro
    Last Post: - 29th September 2004, 03:25
