strange problem ! pic18f4550 & pic16f84a serial communication .
Results 1 to 19 of 19
    Jun 2007
    Default strange problem ! pic18f4550 & pic16f84a serial communication .
    hi everybody .
    here its is what i want to do exactly and wat i got .
    i want to connect 4 pic16f84a to 1 pic18f4550 serially . and every pic16 send
    its portb value to pic18 serially . then pic18 send the value to my pc usb . so i write the code for pic16 and test it on my pc serial port and its working fine and send the right value . what when connect to pic18 , pic18 send wrong values . here is my code and hope to find anything wrong ?
    ' pic16f84a code
    include "modedefs.bas"
    define osc 4
    TRISB = %11111111 ' portb all input
    PORTB = %00000000 ' portb 0
    TX VAR PORTA.2 ' transmmit
    B0 VAR BYTE ' var for store portb value
    B1 VAR BYTE ' var for store portb value
    start :
    B0 = PORTB
    PAUSE 100
    B1 = PORTB
    IF B1 = B0 THEN start
    IF B1<> B0 THEN SEROUT TX,N9600,[B1]
    B1 = B0
    GOTO start
    'pic18f4550 code
    Include "modedefs.bas"
    INCLUDE "DT_INTS-18.bas"
    DEFINE OSC 20
    PORTD = 0
    TRISD = %11111111
    INT_LIST macro
    INT_Handler USB_INT, _DoUSBService, ASM, yes
    INT_CREATE
    endasm
    USBBufferSizeTX con 8
    USBBufferSizeRX con 8
    USBBufferCount Var Byte
    USBBufferIn var byte[8]
    USBBufferOut Var Byte[8]
    DataToSend var byte[8]
    RX VAR PORTD.1
    VAR0 VAR BYTE
    asm
    SendUSB macro array
    variable i=0
    while i<8
    MOVE?BB (array+i),(_USBBufferOut+i)
    i+=1
    endw
    L?CALL _DoUSBOut
    endasm
    SwHwInit:
    GOSUB DoUSBinit:
    Start:
    serin rx,N9600,VAR0
    datatosend[4] = VAR0
    @ SendUSB _DataToSend
    gosub dousbin
    goto start
    DoUSBIn:
    @ INT_DISABLE USB_INT
    USBBufferCount = USBBufferSizeRX
    USBService
    USBIn 1, USBBufferin, USBBufferCount, Timeout
    Timeout:
    @ INT_ENABLE USB_INT
    DoUSBOut:
    WaitPC:
    USBBufferCount = USBBufferSizeTX
    USBService
    USBOut 1, USBBufferOut, USBBufferCount, Waitpc
    usb_device_state var byte EXT
    CONFIGURED_STATE CON EXT
    DoUSBinit:
    usbinit
    repeat
    usbservice
    until usb_device_state = CONFIGURED_STATE
    DoUSBService:
    usbservice
    @ INT_RETURN
    thanks , regards
    Feb 2005
    Essex, UK
    not sure if your Oscillator is set to the correct frequency. 20MHz; should this not be 48MHz? Are you defining the configs correctly for use with PLL?
    For a 20MHz crystal I use these:
        'Config1L
    '    Full-speed USB Clock Source Selection: Clock Source from 96MHz PLL/2
    '    CPU System Clock Postscaler: Prescaler Divide by 5 for 20MHz Crystal
    '    96MHz Prescaler: Divide by 5 (20MHz Input)
    @ __CONFIG _CONFIG1L, _USBDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _PLLDIV_5_1L
        'Config1H
        'Oscillator: HS oscillator, PLL enabled, HS used by USB
        'Fail-Safe Clock Monitor Enable: Enabled
        'Internal External Switch Over Mode: Disabled
    @ __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEM_ON_1H & _IESO_OFF_1H
    Cheers
    Rob
    Jun 2007
    thanks for reply , but when i paste this code i get an error .
    and am sure i setup it to correct frequency .
    error :
    overwriting previous address contents (0000) .
    symbol not previously defined (_fcmem_on_1h) .
    regrads .
    Quote Originally Posted by amenoera View Post
    error :
    I've seen this before somewhere. Don't remember what the deal was.
    Do a search on fcmem and fcmen.
    Should fix you up...
    EDIT: Found it...
    Old versions of MPLAB use FCMEM, new one uses FCMEN
    http://www.picbasic.co.uk/forum/show...m+fcmen&page=3
    Post #82
    Feb 2005
    Essex, UK
    Skimask has given you the answer for the error but the frequency will need to be defined as 48MHz when you correct to FCMEN instead of FCMEM. This is because the config settings I have given you set the PIC to run from 48MHz PLL clock source which is generated by the PIC internally but using your 20MHz crystal as the original clock source.
    Hope this helps. Let us know how you get on.
    Cheers
    Rob
    Jun 2007
    Thumbs up
    woow , yes you are right .
    all i did is :
    1 : for this "symbol not previously defined (_fcmem_on_1h) " error , i changed it
    to "(_fcmen_on_1h" .
    2 : i comment this lines in "18f4550.inc" in my "pbp" folder :
    ; __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ; __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H
    this 2 line is reponsable for this erro "overwriting previous address contents (0000)"
    3 : i change "define osc 20" to "48" .
    after that , all works fine , and i can now send and recive without any problems .
    thanks again .
    regards .
    Feb 2005
    Essex, UK
    Smile
    Excellent,
    glad it's working for you!
    Kind regards
    Rob
    Jul 2016
    Default Re: strange problem ! pic18f4550 & pic16f84a serial communication .
    Hi Rob:
    if pic18f4550 use 16Mhz crystal , how to set 'Config1L to get precise output timing ?
    'Config1L
    'Config1H
    thanks , regards
    Lee
    first off this thread has been inactive for 9 years , is it even relevant to your problem ?
    what output timing ?
    what cpu clock are you aiming for ?
    do you need usb clock ?
    what version of pbp ?
    setting config like this is ancient history
    why not start a new more relevant thread
    Jul 2016
    hello,
    my complier is PBP3 gold 3.0.9.0
    16Mhz crystal work with Pic18f4550
    output timing means : if I toggle portB.4 200 , led should toggle every 200ms , but it output toggle only every 20ms , how can i set exactly config to get precise output ? thanks
    Lee
    maybe you should post the actual code you are trying
    toggle portB.4 200
    is not a valid pbp statement
    is not a valid pbp3 statement
    did you define OSC?
    Jul 2016
    Hi
    my code is simple as follow:
    define osc 48
    TRISB = $00 ' Set digit pins to output
    mainloop:
    toggle portB.5
    pause 200
    Goto mainloop ' Forever
    my complier is PBPX 3.0.9.4
    I measure portB.5 output led by scope, it toggle only every 20ms , only 1/10 of my seeting , how can i set exactly config for 16MHz crystal application to get precise output ?
    I check PBP3\Device\PIC18F4550.PBPINC file internal seting just for 20Mhz
    ; The #CONFIG block is passed directly to the asm file, but PBP will replace it
    ; automagically with the contents of a user-defined #CONFIG block if one is
    ; found in the PBP source program. There is no need to edit or comment this
    ; block in this file. Simply copy it to your source program and edit it there.
    CONFIG PLLDIV = 5 ; Divide by 5 (20 MHz oscillator input)
    CONFIG CPUDIV = OSC1_PLL2 ; [Primary Oscillator Src: /1][96 MHz PLL Src: /2]
    CONFIG USBDIV = 2 ; USB clock source comes from the 96 MHz PLL divided by 2
    CONFIG FOSC = HSPLL_HS ; HS oscillator, PLL enabled (HSPLL)
    CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
    CONFIG IESO = OFF ; Oscillator Switchover mode disabled
    CONFIG PWRT = OFF ; PWRT disabled
    CONFIG BOR = ON ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    CONFIG BORV = 3 ; Minimum setting
    CONFIG VREGEN = ON ; USB voltage regulator enabled
    CONFIG WDT = ON ; WDT enabled
    CONFIG WDTPS = 512 ; 1:512
    CONFIG CCP2MX = ON ; CCP2 input/output is multiplexed with RC1
    CONFIG PBADEN = OFF ; PORTB<4:0> pins are configured as digital I/O on Reset
    CONFIG LPT1OSC = OFF ; Timer1 configured for higher power operation
    CONFIG MCLRE = ON ; MCLR pin enabled; RE3 input pin disabled
    CONFIG STVREN = ON ; Stack full/underflow will cause Reset
    CONFIG LVP = OFF ; Single-Supply ICSP disabled
    CONFIG ICPRT = OFF ; ICPORT disabled
    CONFIG XINST = OFF ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    CONFIG DEBUG = OFF ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    CONFIG CP0 = OFF ; Block 0 (000800-001FFFh) is not code-protected
    CONFIG CP1 = OFF ; Block 1 (002000-003FFFh) is not code-protected
    CONFIG CP2 = OFF ; Block 2 (004000-005FFFh) is not code-protected
    CONFIG CP3 = OFF ; Block 3 (006000-007FFFh) is not code-protected
    CONFIG CPB = OFF ; Boot block (000000-0007FFh) is not code-protected
    CONFIG CPD = OFF ; Data EEPROM is not code-protected
    CONFIG WRT0 = OFF ; Block 0 (000800-001FFFh) is not write-protected
    CONFIG WRT1 = OFF ; Block 1 (002000-003FFFh) is not write-protected
    CONFIG WRT2 = OFF ; Block 2 (004000-005FFFh) is not write-protected
    CONFIG WRT3 = OFF ; Block 3 (006000-007FFFh) is not write-protected
    CONFIG WRTC = OFF ; Configuration registers (300000-3000FFh) are not write-protected
    CONFIG WRTB = OFF ; Boot block (000000-0007FFh) is not write-protected
    CONFIG WRTD = OFF ; Data EEPROM is not write-protected
    CONFIG EBTR0 = OFF ; Block 0 (000800-001FFFh) is not protected from table reads executed in other blocks
    CONFIG EBTR1 = OFF ; Block 1 (002000-003FFFh) is not protected from table reads executed in other blocks
    CONFIG EBTR2 = OFF ; Block 2 (004000-005FFFh) is not protected from table reads executed in other blocks
    CONFIG EBTR3 = OFF ; Block 3 (006000-007FFFh) is not protected from table reads executed in other blocks
    CONFIG EBTRB = OFF ; Boot block (000000-0007FFh) is not protected from table reads executed in other blocks
    thanks
    Lee
    when posting code please use code tags
    http://www.picbasic.co.uk/forum/showthread.php?t=19594
    ;wrong     CONFIG  PLLDIV = 5            ; Divide by 5 (20 MHz oscillator input)
        CONFIG  PLLDIV = 4            ; Divide by4 (16 MHz oscillator input)
     ;wrong  define osc 48   DEFINES ARE CASE SENSITIVE
    define OSC 48
     mainloop:
      toggle portB.5
      pause 200
    Jul 2016
    Hi
    Thanks , I tested PLLDIV = 4 before I posted .
    if set PLLDIV = 4 , its output around 16.8ms , do you think any other setting was wrong ?
    Best regards
    Lee
    The input to the PLL needs to be 4MHz , 16/4 = 4
    CPUDIV = OSC1_PLL2 yields a 48MHz CPU clock if the PLL is fed correctly
    If you don't post you code [in code tags] I would only be guessing
    Jul 2016
    Hi
    thanks Richard , my code as below
    define osc 48
    mainloop:
    toggle portB.5
    pause 200
    your not paying attention the solution has already been offered , and for an issue like this its important to include the config section
    config + program are inseparable for diagnosing this problem
    define osc 48
    mainloop:
    toggle portB.5
    pause 200
    RTFM
    define OSC 48
    Oct 2009
    Just testing, as sometimes I've noticed that when pasting code copied from MCS into the forum, it sometimes re-formats it and changes upper to lower case
    Just ignore this
    DEFINE  OSC 20                          ' 18F4520, 20mhz crystal
    Edit: - seems to work fine so it's not that, so must be human error ;-)
    In MCS keywords are reformatted on the fly - but for display purposes only. The case in which you type it in is what's stored in the actual file. If you typ HsERiN that's what stored when you save the file even if MCS displays HSERIN on the screen.
    define is a keyword so when you type that in MCS it gets reformatted to upper case (if you have your formatting setup that way) but if you then copy/paste that into Notepad or whatever it reverts to the way you typed it (which can be DefINe or whatever). OSC on the other hand - which is the important thing here - is NOT a keyword that MCS recognizes so it does NOT get reformatted and that's a good thing in this case because if it did you'd see OSC on the screen even if you typed it as osc which would then cause the assembler to not recognize it as OSC.
  1. Serial Communication Using PIC16F84A
    By fazan83 in forum GSM
    Last Post: - 22nd January 2007, 02:56
  2. Serial Communication Problems (Strange!!)
    By Armando Herjim in forum Serial
    Last Post: - 20th June 2006, 22:46
  3. Replies: 5
    Last Post: - 20th March 2006, 01:34
  4. Serial Communication Problem
    Last Post: - 23rd February 2006, 02:11
  5. Replies: 8
    Last Post: - 11th November 2004, 20:08
