Time limit while waiting for input ?
Results 1 to 6 of 6
Threaded View
  1. #2
    Default Re: Time limit while waiting for input ?
    is it possible to have a time limit on how long to wait for that low input and if it doesn't happen, the timer will effectively provide the low and the program can continue just as if the sensor worked ?
    the code I posted in this link
    http://www.picbasic.co.uk/forum/show...ht=#post136604
    effectively does this. that's what "run_count" is all about
    when the motor is moving the limit switches are checked every so many mS and the run count decremented
    if a limit is reached or the run count reaches 0 then movement is terminated.
    a run count of 2000 @ 50mS = 100 seconds till timeout
    or
    a run count of 185 @ 100mS = 18.5 seconds till timeout , simply adjust to suit
  1. Upgrade time limit?
    By fowardbias in forum Off Topic
    Last Post: - 5th August 2012, 16:34
  2. Limit of PokeCode??
    Last Post: - 15th June 2012, 20:18
  3. Replies: 0
    Last Post: - 1st December 2010, 22:48
  4. Replies: 11
    Last Post: - 14th May 2010, 10:11
  5. Replies: 4
    Last Post: - 5th October 2007, 10:25
