Time limit while waiting for input ?
Results 1 to 6 of 6
Threaded View
  1. #6
    Default Re: Time limit while waiting for input ?
    I have some doubts about your modification, perhaps you have some noise entering the system, or the limit switch is "bouncing"
    IF limup = 0 OR RUN_COUNT =>0 THEN
    low blue
    low up
    firstly operator precedence make this If test dodgy, parentheses ensure correct result
    IF (limup = 0 ) OR (RUN_COUNT =>0) THEN
    secondly
    RUN_COUNT =>0
    since pbp vars are unsigned , this will always be true it can only be 0 or greater
    since the run_count test always tests true the if statement is always true
    thirdly
    the while loop will only exit if limup is 0 or run_count is 0 , the statement is or should be redundant
  1. Upgrade time limit?
    By fowardbias in forum Off Topic
    Last Post: - 5th August 2012, 17:34
  2. Limit of PokeCode??
    Last Post: - 15th June 2012, 21:18
  3. Replies: 0
    Last Post: - 1st December 2010, 23:48
  4. Replies: 11
    Last Post: - 14th May 2010, 11:11
  5. Replies: 4
    Last Post: - 5th October 2007, 11:25
