Time limit while waiting for input ?
Results 1 to 6 of 6
    Mar 2004
    Default Time limit while waiting for input ?
    I'm using a 16F628A to control a DC motor, also using hall effect sensors as limit switches. All working fine however I'm concerned that if one of the hall sensors should fail the motor will keep running, NOT GOOD !
    The code waits for a low from the hall sensor, is it possible to have a time limit on how long to wait for that low input and if it doesn't happen, the timer will effectively provide the low and the program can continue just as if the sensor worked ?
    For example, the sensor should go low at about 16 seconds, At 18 seconds the timer could provide the low if the sensor didn't. (?)
    Thanks for advice !
    Default Re: Time limit while waiting for input ?
    the code I posted in this link
    http://www.picbasic.co.uk/forum/show...ht=#post136604
    effectively does this. that's what "run_count" is all about
    when the motor is moving the limit switches are checked every so many mS and the run count decremented
    if a limit is reached or the run count reaches 0 then movement is terminated.
    a run count of 2000 @ 50mS = 100 seconds till timeout
    or
    a run count of 185 @ 100mS = 18.5 seconds till timeout , simply adjust to suit
    Mar 2004
    Hi Richard,
    I've been studying your code, (again) I haven't tried to compile the items added in red below as I'm on a different PC right now. I just posted a small part of it for learning.
    Can you tell me if I'm on the right track with how I've added it ?
    So after 100 seconds, if the limit hasn't sent a low, limup pin will still go low ?
    Thanks !
    maxrun con 2000  ;  2000 = 100 sec
    RUN_COUNT VAR word
    moveup:
    high blue
    low blue
    while limup = 1
    high up
    wend
    IF   RUN_COUNT  THEN    ;should the motion continue ?
                 RUN_COUNT = RUN_COUNT -1
    if limup = 0 then
    low up
    goto run
    goto moveup
    hi sam
    I will make some assumptions here
    blue is a led that should flash when moving
    up enables movement
    limup stops movement when low
    this is the movement loop / the only way it stops is if limup = 0
    while limup = 1
    high up
    wend
    its not what you want
    try some thing like this
    moveup:
    high blue   ;  led on
    high up     ;  motor on
    RUN_COUNT=200  ; set time limit 200*500mS  ie 100 sec
    while (limup = 1 ) && ( RUN_COUNT>0) ; do this till time runs out or limit sw trippe
    toggle blue  ; flash led
    wend   ; all done
    low blue
    low up
    Mar 2004
    Richard, you're awesome ! thanks very much !
    This morning is the first chance I've had to try it without constant interruption. I must have done something a little different because it wouldn't work until I added...
    moveup:
    high blue ; led on
    high up ; motor on
    wend ; all done
    IF limup = 0 OR RUN_COUNT =>0 THEN
    low blue
    low up
    Not sure why it doesn't work right without the ">0" but in any case, it's working great. Thanks again !!
    I have some doubts about your modification, perhaps you have some noise entering the system, or the limit switch is "bouncing"
    low blue
    low up
    firstly operator precedence make this If test dodgy, parentheses ensure correct result
    IF (limup = 0 ) OR (RUN_COUNT =>0) THEN
    secondly
    RUN_COUNT =>0
    since pbp vars are unsigned , this will always be true it can only be 0 or greater
    since the run_count test always tests true the if statement is always true
    thirdly
    the while loop will only exit if limup is 0 or run_count is 0 , the statement is or should be redundant
  1. Upgrade time limit?
    By fowardbias in forum Off Topic
    Last Post: - 5th August 2012, 16:34
  2. Limit of PokeCode??
    Last Post: - 15th June 2012, 20:18
  3. Replies: 0
    Last Post: - 1st December 2010, 22:48
  4. Replies: 11
    Last Post: - 14th May 2010, 10:11
  5. Replies: 4
    Last Post: - 5th October 2007, 10:25
