HB100 radar module
Results 1 to 9 of 9
    Default HB100 radar module
    Hello all,
    I try to find something about that MW radar module on PB forum but no success. I have already done the backpack module from limpkin, all works fine. I can read frequencies on scope but how to implement this data to speed measurement?
    I find some code for Arduino in C but nothing in Basic. Can you someone explain me how to or links to picbasic (basic) code snippets?
    Thanks.
    Default Re: HB100 radar module
    Looks like you are the first one here to try to interface with the HB100.
    in past (month ago) I was saw some informations about HB100 with example codes on protonbasic forum but I did not pay attention.
    At this time I cant find anything about this on proton basic forum. It looks like wiped or something.
    Jan 2006
    Istanbul
    HB100 speed measurement is explained here:
    From the first page:
    ......IF the target is moving straight toward or away from HB100 (Ft = 10.525 Ghz) the formula is simplified to:
    Fd = 19.49V (Velocity in km/hour) or 31.36V (V in mile per hour)
    So we are going to use the simplest of the two, we know the doppler frequency, and we want to find the speed.
    V = Fd/31.36 … What this really means thou, is for ever 31.36Hz will equal 1 MPH
    So if the IF Frequency is 31.36 then the speed of the target is 1 MPH. Easy!
    And a IF Frequency of say 400Hz would be about 13Mph if you round it up.
    So if you read the frequeny with a Timer running in the background, then there it is your result.
    Now it's more clear. I try to search simple and working frequency meter code on PB forum, but no success.
    Have someone already done and willing to share the frequency meter source code in picbasic? I'll be grateful for that.
    Louis
    Hi Louis
    You did not say which pic you are using. You can read frequency by feeding the signal to the external timer input on your pic. It works by setting the TMR1 register to 0 , start the timer, let it count for a fixed period of time, stop the timer, read the value in TMR1 to variable Freq and display. The Pause routine is not super accurate for gating the timer so you need to tweak the value. A better way would be to use a second timer with an interrupt. This should get you started
    Freq var word
    'Read Freq
         T1CON = %00000110  'No prescale/Osc off/Sync off/External source/TMR1 off
         TMR1L = 0 ' Clear Timer1
         TMR1H = 0 ' Clear Timer1
         T1CON.0 = 1 ' Start 16-bit timer
         Pause 100    'Capture  of Input Frequency 0.1sec  Pause 1000 =1sec
         T1CON.0 = 0 ' Stop 16-bit Timer
    		Freq.lowbyte = TMR1L 'Read  Tmr1 count to low byte
    		Freq.highbyte = TMR1h 'Read  Tmr1 count to high byte
  1. Cellular module?
    By Art in forum GSM
    Last Post: - 13th April 2012, 18:22
  2. RF module help
    By greensasquatch in forum mel PIC BASIC Pro
    Last Post: - 8th September 2008, 19:50
  3. Replies: 1
    Last Post: - 27th July 2008, 07:14
  4. RF Module
    By shahidali55 in forum General
    Last Post: - 9th March 2007, 10:00
  5. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 08:14
