Byte to Hex
Results 1 to 8 of 8
Thread: Byte to Hex
    Aug 2003
    Default Re: Byte to Hex
    If that were to be output as a pair of ASCII bytes, I might go (after the above code)..
    IF bytea > 9 THEN
    bytea = bytea + $07
    bytea = bytea + $30
    IF byteb > 9 THEN
    byteb = byteb + $07
    byteb = byteb + $30
    Sep 2009
    Or simple use arraywrite:
    OutputArray VAR BYTE[6]
    ARRAYWRITE OutputArray,[HEX2 byte1, HEX2 byte2,..., HEX2 byte6]
    OutputArray VAR BYTE[6] ???
    OutputArray VAR BYTE[12]
    OK
    You might try using:
    HEX1 VAR WORD
    HEX2 VAR WORD
    BYTE1 VAR BYTE (etc)
    BYTE1 = HEX1.HIGHBYTE
    BYTE2 = HEX1.LOWBYTE
  1. HEX byte to ASCII output...
    By johnmaetta in forum mel PIC BASIC Pro
    Last Post: - 13th August 2011, 00:31
  2. Increment a Byte
    Last Post: - 21st November 2009, 11:09
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  4. Convert 3-byte hex to dec to display on LCD
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 10th June 2005, 19:20
  5. Splitting a byte?
    By Deadeye in forum General
    Last Post: - 29th May 2005, 21:58
