Pcf8574 i2c lcd
Results 1 to 3 of 3
Thread: Pcf8574 i2c lcd
Threaded View
    Aug 2008
    Default Pcf8574 i2c lcd
    Hello anyone to help me 12c
    PCF8574 Does Not Work on Test Board
    Only works on proteus
    Here are all the files
    Thank you
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 8/20/2016                                         *
    ;----[16F873AHardware Configuration]-------------------------------------------
        __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _CP_OFF & _PWRTE_OFF & _WDTE_OFF
    ;----[Oscillator Setup]---------------------------------------------------------
    DEFINE OSC 12
    TRISA = %11111100:PORTA=0
    TRISB = %11111111:PORTB=0
    TRISC = %11100111:PORTC=0
    ;----[Aliases]------------------------------------------------------------------
    SDA         VAR PORTC.4      ;I2C Data pin
    SCL         VAR PORTC.3      ;I2C Clock Pin
    ;----[Initialize Hardware]------------------------------------------------------
     ADCON1 = 7
    ;----[Setup LCD using PCF8574 Port Expander]------------------------------------
    LCD_Addr    CON $40           ;A0,A1,A2 tied to ground
    INCLUDE "LCD_PCF8574.pbp"     ;Include LCD module for PCF8574
    ;----[Variables]----------------------------------------------------------------
    LoopCount       VAR BYTE
    CustChar        VAR BYTE
    ;----[Program Start]------------------------------------------------------------
    Backlight = 0                ;Turn on LCD Backlight
    ARRAYWRITE LCD_Buff,["   LCD PCF8574"] : LCD_WriteBuff
    LoopCount= 0
    ;----[Custom Characters]-(Jumping Jacks)----------------------------------------
    ARRAYWRITE LCD_Buff,[$FE,$40,$00,$04,$0A,$04,$0E,$15,$0A,$11]:LCD_WriteBuff ' #0
    ARRAYWRITE LCD_Buff,[$FE,$48,$00,$04,$0A,$04,$1F,$04,$0A,$0A]:LCD_WriteBuff ' #1
    ARRAYWRITE LCD_Buff,[$FE,$50,$04,$0A,$15,$0E,$04,$0A,$0A,$00]:LCD_WriteBuff ' #2
    ;----[Main Program Loop]--------------------------------------------------------
        ARRAYWRITE LCD_Buff,[$FE,$C0,"Count = ",DEC LoopCount,"   "] : LCD_WriteBuff
        PAUSE 200
        LoopCount = LoopCount + 1
        CustChar = LoopCount//3   ; Jumping Jacks Sequence
        ARRAYWRITE LCD_Buff,[$FE,$9D,CustChar] : LCD_WriteBuff
    GOTO Main
    ; File Name   : LCD_PCF8574.pbp
    ; Author      : Darrel Taylor
    ; Created     : Mon Feb 24 2014
    ; Compiler    : PicBasic Pro 3.0.6.x or higher
    ; Description : Uses PCF8574 Port expander to interface with HD44780 LCD
    LCD_BuffSize    CON 30
    LCD_Buff        VAR BYTE[LCD_BuffSize]
    LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Data        VAR BYTE        ; Data to Send to LCD
    LCD_Byte        VAR BYTE        ; Nibbles to Send
    LCD_E           VAR LCD_Byte.4  ; Enable bit
    LCD_RW          VAR LCD_Byte.5  ; Read/Write bit
    LCD_RS          VAR LCD_Byte.6  ; Register Select bit
    BackLight       VAR LCD_Byte.7  ; Backlight 0=ON
    LCD_WriteMode   VAR BYTE        ; 1=LowNibble, 2=HighNibble, 3=Both
    LCD_CommandMode VAR BIT         ; Indicates next byte is a command
    LCD_Byte2       VAR BYTE        ; Same nibble without E bit
    LCD_Idx         VAR BYTE
    GOTO Over_LCDPCF8574
    ;----[Write 1-byte to LCD]--(Input is LCD_Data)---------------------------------
    USERCOMMAND "LCD_WRITE"
    LCD_WRITE_:
        LCD_E = 1
        IF LCD_WriteMode.1 THEN                                  ; Write High Nibble
            LCD_Byte = (LCD_Byte & $F0) | ((LCD_Data >> 4) & $0F)
            LCD_Byte2 = LCD_Byte & $EF
            I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
        IF LCD_WriteMode.0 THEN                                  ; Write Low Nibble
            LCD_Byte = (LCD_Byte & $F0) | (LCD_Data & $0F)
    LCD_WRITE?  macro
        L?CALL _LCD_WRITE_
    ;----[Write contents of buffer to LCD]------------------------------------------
    USERCOMMAND "LCD_WRITEBUFF"
    LCD_WRITEBUFF_:
        LCD_BuffLen = R5 - LCD_BuffAddr -1
        LCD_WriteMode = 3          ; Both Nibbles
        LCD_CommandMode = 0
        FOR LCD_Idx = 0 TO LCD_BuffLen
            IF LCD_Buff(LCD_Idx) = $FE THEN LCD_CommandMode = 1 : GOTO LCD_ByteDone
            IF LCD_CommandMode THEN
                LCD_RS = 0
                LCD_CommandMode = 0
                LCD_RS = 1
            LCD_Data = LCD_Buff(LCD_Idx)
            LCD_Write
                PAUSE 2
                PAUSEUS 50
          LCD_ByteDone:
        NEXT LCD_Idx
        LCD_CommandMode = 0
    LCD_WRITEBUFF?  macro
        L?CALL _LCD_WRITEBUFF_
    Over_LCDPCF8574:
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250                         ; LCD Power-on delay
    Backlight = 1                     ; Backlight OFF
    LCD_RW = 0                        ; Write to LCD
    LCD_RS = 0                        ; Command Register
    LCD_WriteMode = 1                 ;-- Low Nibbles only
    LCD_Data = 3                      ; Reset 3 times
    LCD_Write : PAUSEUS 6000
    LCD_Write : PAUSEUS 1000
    LCD_Data = 2                      ; Start 4-bit mode
    LCD_WriteMode = 3                 ;-- Both Nibbles
    LCD_Data = $28 : LCD_Write        ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C : LCD_Write        ; Display ON
    LCD_Data = $01 : LCD_Write        ; Clear Screen
    PAUSE 2
    LCD_Data = $06 : LCD_Write        ; Entry Mode
    PAUSE 2                           ; Let command finish
  1. I2C LCD
    By midali in forum General
    Last Post: - 8th January 2021, 23:52
  2. Pic12f675 + Pcf8574 + Lcd
    By Bostjan in forum mel PIC BASIC Pro
    Last Post: - 4th November 2016, 18:54
  3. Replies: 3
    Last Post: - 15th October 2012, 09:06
  4. I2C PCF8574 4X4 Keypad routine
    Last Post: - 28th January 2007, 22:25
  5. I2C I/O Expander PCF8574 hanging?
    By NavMicroSystems in forum Serial
    Last Post: - 4th August 2005, 03:26
