Code interpretation
Results 1 to 5 of 5
    Aug 2003
    Default Code interpretation
    Hi Guys
    I’m trying to port PBP code for Tetris I wrote some years ago to C,
    and have come across this:
    digits var byte [4]					'
    D0 var digits[0]					'
    D1 var digits[1]					'
    D2 var digits[2]					'
    D3 var digits[3]					'
    IF D0.0(valuea + valueb) = 1 THEN			'
    valuec = 1						'
    ENDIF							‘
    Does it do what I think it does and check any bit at offset (value + valueb) in the array?
    At some stage I knew for sure It will take more trickery to do it in C, it’s not too accommodating at accessing bits.
    Cheers, Brek.
    Sep 2009
    Default Re: Code interpretation
    Yes
    And some text to make post longer than 10 chars...
    Aug 2003
    I think the code didn’t ever make it try to look outside the first byte in the array anyway,
    and the input value never added up to more than 7, but if it can look into other bytes, that’s useful.
    Sep 2009
    PBP doesn't check array limits. That is true for all variables types. So you can scan thru all pins of all ports with PORTA.0[i]...
    Aug 2003
    That was interesting.
    The Tetris was monochrome for an LED board, so the Tetris shapes and the well were all arrays of bits.
    To write the same thing in C inflates the program, but uses no more RAM.
    Rewriting it in C dealing with bytes instead of bits uses less program memory on the C platform, but much more RAM.
  1. avr code to code for PIC
    By JasonMcG in forum General
    Last Post: - 11th September 2014, 01:57
  2. Serial problem between BasicStamp code and PBP code
    By AllanZilkowsky in forum mel PIC BASIC Pro
    Last Post: - 6th April 2014, 03:15
  3. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
