Temperature probe options
Results 1 to 3 of 3
    Default Temperature probe options
    I have a lot of an old PIC, the 16C72 and may use them in a temperature switch. I know the ADC is 8 bit but don't need real high accuracy in the readings.
    What would be my best options (or maybe my only options), for a ready made temperature probe? I see some on Ebay -- one that is LM35 based and another DS1820. Others ?
    Never messed around with temp sensors at all before. I do see some ready made code (or adaptable) for the DS1280 in the example programs.
    Thanks kindly.
    Default Re: Temperature probe options
    LM35 output 10mV / deg , 8 bit ADC @5v is 20 mV / count , that's a pretty chunky result . 4x oversampling could help
    if you need to measure below 0c a neg voltage source is req.
    DS18S20 code is subtlety different to DS18B20 code , watch for that . either will measure sub zero C temps
    {I find if parasitic power not used and/or conversions are frequent they can self heat giving false readings unless well heatsinked }
    a DS1280 is part of a mac truck
    Ok -- yes, seems the DS1820 is the current "best choice". Thanks.
  1. Saleae Logic Probe on sale at microchip.com
    By ScaleRobotics in forum Off Topic
    Last Post: - 27th September 2024, 11:26
  2. Logic Probe Recommendations
    By retepsnikrep in forum Off Topic
    Last Post: - 12th June 2011, 20:35
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 20:43
  4. Hot Tub Temperature Probe
    By DavidK in forum Off Topic
    Last Post: - 22nd November 2008, 10:45
  5. PH Probe A/D Coverter ?
    By shawn in forum Schematics
    Last Post: - 27th August 2008, 10:44
