A question for the Macro experts....
Results 1 to 17 of 17
    forgie's Avatar
    forgie Guest
    Yes, I was aware of that after reading one of your earlier posts. I am sitting slightly under 50% of my available code space (on an 18f452), and on top of that the data sending routines are used in a part of the code where speed is preferable (but not critical). To use the fastest method I would have to find out what macros HSEROUT calls, and call them directly somehow.... and the smallest code version would be something along the same lines using gosubs. Anyway if the timing becomes more important or code space is an issue then I will rewrite the macro. But for the meantime, I have improved readability by a large degree. Thanks for the ideas/wisdom guys, it's great to know that there's such a concentrated pool of knowledge in this forum to ask when I have a tough PBP question.....
    forgie's Avatar
    forgie Guest
    Red face
    Also.... the macro method makes me feel like my code is more 'modular,' and more like a functional language, which makes me feel warm inside
    If you want to shrink your code, the best way is to see if you can use the internal ressource instead of the PBP pre-made function.
    By example, instead of using ADCIN, write/read directly to the register, same for HSEROUT, HSERIN and how much others.
    For a simple HSEROUT
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    RCSTA =$90
    TXSTA =$24
    SPBRG= 129 ' 9600 Bauds
    aVar    var BYTE[7]
    a       var byte
    avar[0]="H"
    avar[1]="E"
    avar[2]="L"
    avar[3]="L"
    avar[4]="O"
    AVAR[5]=13
    AVAR[6]=10
    A=0
    start:
        REPEAT
            TXREG=AVAR[A]
            NotEmpty: if TXSTA.1=0 then notempty
            A=A+1
            UNTIL A=7
            A=0
            PAUSE 500
          goto start
    compile 89 words
    DEFINE OSC 20
    RCSTA =$90
    TXSTA =$24
    aVar    var BYTE[7]
    avar[0]="H"
    avar[1]="E"
    avar[2]="L"
    avar[3]="L"
    avar[4]="O"
    AVAR[5]=13
    AVAR[6]=10
    start:
        HSEROUT[STR AVAR]
        PAUSE 500
        goto start
    compile 103 words.
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 129 ' 9600 Bauds
    aVar    var BYTE[7]
    avar[0]="H"
    avar[1]="E"
    avar[2]="L"
    avar[3]="L"
    avar[4]="O"
    AVAR[5]=13
    AVAR[6]=10
    start:
        HSEROUT[STR AVAR]
        PAUSE 500
        goto start
    almost the same as the previous but using PBP DEFINE HSER compile 95 words
    No big improvement so far... i should find a better example next time
    BTW it's always case by case. Scroll your program and look wich statement you call the most, do a SUB with them and TADA. Just be sure to avoid too much nested gosub and it should gives you good results.
    BUT there's always a midpoint between a readable code, and a tight one. Choose your own comfort zone and work with.
  1. PBPro error "Macro USBINIT? not found in macro file"
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 10:06
  2. Replies: 6
    Last Post: - 4th November 2009, 14:36
  3. Really simple question for you experts :)
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 4th June 2008, 02:43
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Passing an array as a macro argument?
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 18:09
