serin
Results 1 to 3 of 3
Thread: serin
    Aug 2005
    Smile serin
    Im trying to make a protocol converter using the serin an serout commands. The device sends instructions of varying length. That’s the problem. Ive used SERIN PortB.5,N9600,b0,b1,b2,b3 but some of the instructions only use b0,b1 so the serin command is still waiting for b2 and b3. Ive also tried adding the timeout instruction to the command to reset serin, this does work 90% of the time but it tends to miss out instructions during the time out.
    (b0,b1,b2,b3 are var bytes)
    Any ideas Sphere.
    If your PIC have an internal USART... use it. Use the USART interrupt to get your data, then send it where you want.
    No timeout hassle and all this kind of future problem. Do a search with USART Inerrupt and you should find more than enough to begin
    Receive your data, one byte at the time, then you can store them in an aray, EEPROM, send it to LCD.........
    Aug 2005
    Smile Serin
    Thanks for the reply I will give it a go.
    Sphere....
  1. Serin EEPROM Programmer
    By dirtbiker5627 in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 23:48
  2. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 22:03
  3. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  4. Serin with low voltage
    By f_lez in forum General
    Last Post: - 21st August 2006, 11:52
  5. SerIn and SerOut
    By Dwayne in forum FAQ - Frequently Asked Questions
    Last Post: - 21st July 2004, 15:54
