Hi All!
I have a confusion. If I use a single TRISB Statement TRISB = %10000100 the program will stop dead at the next line of code.
If I use single TRISB statements:
TRISB.4 = 0 ' Make B.4 an OUTPUT
TRISB.6 = 0 ' Make B.6 an output
TRISB.5 = 0 ' Make B.5 an output
TRISB.7 = 1 ' Make B.7 an INPUT
TRISB.3 = 0 ' Make B.3 an OUTPUT
The code will run!
chip is a 16F628A
Do I need a CMCON = 7 or an ADCON or ???Code:'**************************************************************** '* Name : STV-SYNCHS RELEASE * '* Author : BOB LEGGETT * '* Notice : Copyright (c) 2009 * '* : All Rights Reserved * '* Date : around 2009 or so rehashed now '17 * '* Version : 1.0 * '* Notes : VIDEO IDENT * '* : * '**************************************************************** ' WORKS USES SYNC FOR SWITCHING BETWEEN MIXED AND FULL TEXT MODE ' GOING FROM VID IN TO TEXT AND BACK TO VID IN ' INCLUDE "ALLDIGITAL.pbp" define OSC 20 #CONFIG __config _HS_OSC & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF #ENDCONFIG 'TV CHIP CONNECTIONS '--------------------------------------------------------------- '16f628a TVSDA VAR PORTB.4 '0 OUTPUT pin 11 stv was b.1 CS0 VAR PORTB.6 '0 OUTPUT pin 13 stv was b.0 TVSCL VAR PORTB.5 '0 OUTPUT pin 12 stv was b.5 SYNCH0 VAR PORTB.7 '1 'INPUT to pin 7 stvchip was b.2 HEARTBEAT VAR PORTB.3 'OUTPUT 0 led was b.6 '--------------------------------------------------------------- ZOOMREG CON %0000000011001100 ' 12 ZOOM REGISTER COLREG CON %0000000011001101 ' 13 COLOUR REGISTER CONREG CON %0000000011001110 ' 14 CONTROL REGISTER POSREG CON %0000000011001111 ' 15 POSITION REGISTER MODEREG CON %0000000011010000 ' 16 MODE REGISTER ICOUNT VAR BYTE BITCOUNTER VAR BYTE WDATA VAR WORD CHARCOUNTER VAR BYTE ' LINECOUNTER VAR BYTE ' STVCHAR VAR BYTE ASCCHAR VAR BYTE CHARS VAR BYTE CHARS2 VAR BYTE TEMP VAR BYTE TEMP1 VAR BYTE COUNTER VAR BYTE PULSES VAR BYTE CURRENTMODE0 VAR BYTE '---------------------------------------------------------------- ' TOPLEFT CON 0 ' TOPMIDDLE CON 5 ' TOPRIGHT CON 10 ' BOTLEFT CON 2560 '10*256 ' BOTMIDDLE CON 2565 '(10*256)+ 5 ' BOTRIGHT CON 2570 '(10*256)+ 10 '---------------------------------------------------------------- DATA @0,"TEST.",$FF,"NO SYNCHS RECEIVED",$FF TRISB.4 = 0 ' Make B.4 an OUTPUT TRISB.6 = 0 ' Make B.6 an output TRISB.5 = 0 ' Make B.5 an output TRISB.7 = 1 ' Make B.7 an INPUT TRISB.3 = 0 ' Make B.3 an OUTPUT '---------------------------------------------------------------- '628 ' TRISB = %10000100 '---------------------------------------------------------------- PAUSE 500 HIGH HEARTBEAT GOSUB Init PAUSE 500 GOSUB Init CURRENTMODE0=255 ' FORCES TRYSYNCHS TO SET MODE FIRST TIME Demo: CHARCOUNTER = 0 LINECOUNTER = 0 ' CURRENTMODE0 = 0 '0 = MIXED 1 = TEXT gosub CLS GOSUB TRYSYNCHS '================================== TEMP = 0 LOOPER: GOSUB HEADER ' LINE 3 RIGHT HAND SIDE TEST. IF CURRENTMODE0=1 THEN GOSUB NOVIDEO ' DISPLAYS NO VIDEO IF NO INCOMING SYNCHS ENDIF GOSUB TRYSYNCHS '=========================== PAUSE 500 'I/2 SECOND DELAY TOGGLE HEARTBEAT ' LED GOTO LOOPER 'DO IT FOREVER DISPLAYCHAR: WDATA = %0001011100000000 + STVCHAR GOSUB SEND RETURN SETLINE: WDATA = LINECOUNTER*256 + CHARCOUNTER GOSUB Send 'position cursor RETURN WasteTime: ' WORKS WITH LESS NOPS pauseus 20 ' was 20 nops RETURN StartCommunication: TVSCL = 1 'HIGH TVSCL GOSUB WasteTime CS0 = 0 'LOW CS0 GOSUB WasteTime TVSCL = 0 'LOW TVSCL GOSUB WasteTime RETURN StopCommunication: TVSCL = 1 'HIGH TVSCL GOSUB WasteTime CS0 = 1 'HIGH CS0 GOSUB WasteTime RETURN SendOne: TVSDA = 1 'HIGH TVSDA GOSUB WasteTime TVSCL = 0 'LOW TVSCL GOSUB WasteTime TVSCL = 1 'HIGH TVSCL GOSUB WasteTime RETURN SendZero: TVSDA = 0 'LOW TVSDA GOSUB WasteTime TVSCL = 0 ' LOW TVSCL GOSUB WasteTime TVSCL = 1 'HIGH TVSCL GOSUB WasteTime TVSDA = 1 'HIGH TVSDA GOSUB WasteTime RETURN OutByte: FOR BITCOUNTER = 1 TO 16 IF WDATA.15 = 1 THEN GOSUB SendOne ELSE GOSUB SendZero ENDIF WDATA = WDATA << 1 NEXT BITCOUNTER RETURN Send: GOSUB StartCommunication GOSUB OutByte GOSUB StopCommunication RETURN '------------------------------------------------------------- Init: ' PAUSE 50 added - seems to improve reliability of init TVSCL = 1 'HIGH TVSCL TVSDA = 1 'HIGH TVSDA CS0 = 1 'HIGH CS0 WDATA = $3000 '%110000 00000000 GOSUB Send ' Init STV5730 PAUSE 50 WDATA = $3000 GOSUB Send PAUSE 50 WDATA = $00DB '%00000000 11011011 GOSUB Send PAUSE 50 WDATA = $1000 '%00010000 00000000 GOSUB Send PAUSE 50 '------------------------------------------------------------- WDATA = %0000000011001100 GOSUB Send ' Init registers (point to register 12) PAUSE 50 '------------------------------------------------------------- WDATA = %0001000000000000 'NORMAL ' WDATA = %0001000011110000 '4 PIXELS HORIZ AND VERT GOSUB Send ' Zoom ADDRESS 12 PAUSE 50 '------------------------------------------------------------- WDATA = %0001001000000000 ' WDATA = %0001001000000100 GOSUB Send ' Color ADDRESS 13 PAUSE 50 '-------------------------------------------------------- WDATA= %0001101011010100 'CHANGE BIT 0 TO 1 FOR TEXT ONLY GOSUB Send ' Control ADDRESS 14 '------------------------------------------------------------- WDATA = %0001011111001111 GOSUB Send ' Position ADDRESS 15 '------------------------------------------------------------- WDATA = %0001000100101110 '$183E BIT 11 CHANGED TO 0 M4 = 0 GOSUB Send ' Mode ADDRESS 16 %0001100000111110 '------------------------------------------------------------- WDATA = $00C0 '%00000000 11000000 GOSUB Send ' Set row attributes FOR ICOUNT = 0 TO 10 WDATA = $10C4 '%00010000 11000100 ' WDATA =%0001000010000111 GOSUB Send NEXT ICOUNT RETURN CLS: 'character=$0B 'SPACE TEMP1=0 ' LINECOUNTER TEMP =0 'CHARCOUNTER loop2: WDATA = 0 ' LINECOUNTER*256 + CHARCOUNTER ADDRESS GOSUB Send LOOP3: ' :CHARACTERS WDATA = %0001011100001011 ' 1011 0BH SPACECHARACTER GOSUB Send TEMP = TEMP + 1 IF TEMP >= 28 THEN TEMP = 0 TEMP1=TEMP1 + 1 ENDIF IF TEMP1 >= 11 THEN SCREENBLANK GOTO LOOP3 SCREENBLANK: RETURN GETSTVCHAR: 'CONVERT ASCII TO STV STVCHAR =$7F ' FORCES CLOCK PICTURE IF ERROR LOOKDOWN ASCCHAR,["0123456789- ABCDEFGHIJKLMNOPQRSTUVWXYZ:./'abcdefghijklmnopqrstuvwxyz"],STVCHAR RETURN HEADER: LINECOUNTER=2 'SET START POSITION CHARCOUNTER=23 'SET CURSOR POSITION GOSUB SETLINE FOR CHARS2=0 TO 4 READ CHARS2, ASCCHAR gosub GETSTVCHAR 'CONVERT ASCII TO STV GOSUB DISPLAYCHAR NEXT RETURN NOVIDEO: LINECOUNTER=5 'SET START POSITION CHARCOUNTER=4 'SET CURSOR POSITION GOSUB SETLINE FOR CHARS2=6 TO 23 ' FROM EEPROM DATA READ CHARS2, ASCCHAR gosub GETSTVCHAR 'CONVERT ASCII TO STV GOSUB DISPLAYCHAR NEXT RETURN TRYSYNCHS: PULSES=0 COUNT SYNCH0,4,PULSES '3MS SHOULD COUNT TO 2 OR 3 IF PULSES > 0 THEN MIXED0 FULL0: IF CURRENTMODE0=1 THEN RETURN WDATA= %0000000011001110 'CONTROL REGISTER GOSUB SEND WDATA= %0001101011010101 ' was 0001101111010101 'CHANGE BIT 0 TO 1 FOR TEXT ONLY OTIGINAL 'WDATA= %0001101111010100 'CHANGE BIT 0 TO 1 FOR TEXT ONLY GOSUB SEND STAYHERE02: CURRENTMODE0=1 GOSUB CLS GOBACK0: RETURN MIXED0: IF CURRENTMODE0=0 THEN RETURN WDATA= %0000000011001110 'CONTROL REGISTER GOSUB SEND WDATA= %0001101011010101 'was 0001101111010100 GOSUB SEND STAYHERE01: CURRENTMODE0=0 GOSUB CLS RETURN
Just in my normal confused state!
Thanks, Ed
