@ device ?????
Results 1 to 2 of 2
Thread: @ device ?????
    Mar 2011
    Los Angeles, California
    Default @ device ?????
    Hi!
    I have seen Config and have never seen "@ device PIC16F628A,HS_OSC,BOD_ON,MCLR_ON,PWRT_ON"
    Is this valid?
    How do I change it for a 20MHZ crystal?
    Thanks, Ed
    Default Re: @ device ?????
    I believe that is the syntax for setting the CONFIG bits when using the old, obsolete, PM assembler. If you have PBP3 you must change it the "new" syntax.
    Find the .INFO file for your device in the DEVICE REFERENCE folder - there you can see what the defaults are and what options are available. HS_OSC is the correct option for a 20MHz.
  1. Replies: 1
    Last Post: - 5th October 2011, 08:59
  2. Target Device does not match selected device
    By queenidog in forum FAQ - Frequently Asked Questions
    Last Post: - 25th June 2011, 00:24
  3. device not recognized
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st November 2009, 17:21
  4. Target device <> Selected Device????
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 21:18
  5. mass storage device 1 MB Flash device
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 31st August 2006, 03:11
